Link explaining gear ratios with motors,etc...
Hi,
I'm coming back to the hobby and was curious if there was a link anywhere explaining how gear ratios work on rc cars with particular motors, etc... Thanks. |
comeseethis.com Is one that I have used a couple times
Hi,
Thanks for the link. I was hoping for something explaining how to calculate things myself. This seems limited as it doesn't show many motors for instance for the SC10 4x4 Thanks. |
Try this, has more vehicles:
http://www.gearchart.com/ Thing to remember there is no exact gearing. There is allot of outside influences that will cause change in gearing. Heat is the number one. You will start with a base FDR then heat will determine moving up or down. These links are there to get you started. Then the experimenting begins. |
Thanks so much.
