Old 09-27-2004, 08:07 AM   #1
Arrow Severe Understeering....Help Please
Hey,
While bashing my Kyosho Ultima buggy at the local BMX track i noticed severe understeer, for example, on a large banked turn with say a 10 metre radius, the buggy, even with full lock would just push so bad that it was climbing right up to the rim of the banked turn, i had to back off to half throttle to get the front end to bite at all.
My setup (sorry if this is n00bish)
Rear
Proline Bowtie M3's and inserts that came with tires, 2 degrees toe in, 0 degrees camber, 0 degree castor, 70wt shock oil, stock springs.
Front
Stock HARD 3 rib Kyosho kit tires, no inserts, 0 degree toe, 2 degrees camber, stock 20 degree castor (fixed), 70 wt shock oil, stock springs.
By the way, the track is fairly hard pack with a very thin layer of rubble/gravell/dirt ontop.
Please somebody help me find my bearings, i just want a neutral handling, slightly understeering by default, but neutral to slight oversteer under power.
Thanks in advance,
Jamie Kulhanek
jamiekulhanek is offline   Reply With Quote
Old 09-27-2004, 08:21 AM   #2
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Change front tires! Go with a Losi Wide Body rib in silver compound and stuff 3/4 of a rear tire insert in there. 70wt sounds pretty high for oil but not sure what range your buggy runs. Good luck.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 09-27-2004, 08:33 AM   #3
Unfortunately i have no access to losi tyres is it a dead end after that?
Old 09-27-2004, 08:33 AM   #4
Nitro Tech
dino.tw's Avatar
Yes,I also think 70wt is too high for buggy. If I'm not wrong,most people use 25~35wt only. Do you use stock shock' pistons or you have modified them?
dino.tw is offline   Reply With Quote
Old 09-27-2004, 08:46 AM   #5
the shock pistons are stock...
I had no idea in the beginning, and neither did my LHS so i got the 70wt.
I'll go and get some 25-30wt tomorrow.
Any other ideas???
Old 09-27-2004, 08:53 AM   #6
Oh geez, i just realised i posted this in the wrong damn forum
It should be in the electric and nitro offroad forum.
Old 09-27-2004, 09:22 AM   #7
Jack Smash's Avatar
Just about any front tire will be better than what you got there. Not sure what you have available but Proline, Schumacher and Yokomo offer other tires as well.
Old 09-27-2004, 10:47 AM   #8
You want to see if you can adj. your transmitters epa (end point adj) for the steering. Maybe the servo isn't going all the way to each side?
jnims29 is offline   Reply With Quote
Old 09-27-2004, 11:44 AM   #9
Nitro Tech
dino.tw's Avatar
That is ok. If you need help,many RC addicts will help you no matter where. But if you would like to move this thread to the electric and nitro offroad forum,let me know. I can do it.
Old 09-27-2004, 09:16 PM   #10
nah the steering servo is travelling to full excursion, just crap traction....
Old 09-27-2004, 09:35 PM   #11
dino, yes could you please move it to the correct forum, thanks.
Old 09-28-2004, 12:22 AM   #12
Aaron Waldron's Avatar
Lower the front ride height, dial in some drag brake, change front tires, add more negative camber, or soften up your shocks.
Any of those should help.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Severe Glitching on Hyper 8.5pro rcrevolution Nitro Off-Road 12 08-03-2008 08:04 PM
how to eliminate understeering on my buggy(hyper7)? vyt666 Nitro Off-Road 3 07-29-2008 12:10 AM
**Severe Revo Abuse Video..06/21/05** airmaxx23 Monster Trucks 5 07-03-2005 07:38 AM
**Revo Severe Abuse Video...06/21/05** airmaxx23 Monster Trucks 0 06-21-2005 09:38 PM
Severe Glitching Problem - Please Help! Accord Electric On-Road 2 06-18-2003 02:44 AM
