Yokomo B-MAX2 buggy thread >
Old 05-27-2012, 03:24 AM
  #361
ViGiLaNtE351's Avatar
Any pin style ..
ViGiLaNtE351 is offline
Old 05-27-2012, 07:43 AM
  #362
mes
Kit setup is pin-style. I use the PL hex conversion in the rear in combination with some 2.5 mm spacers (Kyosho LA-253). Bearings in the front are inside the wheels (5 mm axles; AE conversion available).
mes is offline
Old 05-29-2012, 12:08 AM
  #363
littlevette's Avatar
Trader Rating: 22 (100%+)
did anyone from the states get a bmax2 kit from driftspeed.com? if you did, did you get replacement outdrives for the defective units?
if anyone has talked to katsumi successfully please let me know.
littlevette is offline
Old 05-30-2012, 12:58 AM
  #364
ScottyP's Avatar
Got my kit today. Can't wait to build and run it! Been a while now since I've run a rear engined car
I can't speak highly enough of the service from RC-Champ in Japan. The key is to have all the part numbers and simply drop them an email.
Prices are VERY good too. Paid US$280 for the kit. Shipping is a little high, but they use EMS, which is super fast! Three working days from Japan to Australia.
Also managed to score the World Spec Conversion for my B-Max 4. Last one they had in stock and it's discontinued
Cheers,
Scott
ScottyP is offline
Old 05-30-2012, 03:34 AM
  #365
You will not be disappointed!
Old 05-31-2012, 05:47 PM
  #366
RAL
RAL's Avatar
Trader Rating: 64 (100%+)
Regarding the updated diff drive cups for the Bmax2 with the harder material, Is it part # B2-501 or does it have a new number? How am I able to make sure they are the "new" ones?
RAL is offline
Old 06-01-2012, 12:19 PM
  #367
mes
Parts number is the same. Anodising on the new ones seems to be slightly darker and does not rub off that easily.
mes is offline
Old 06-06-2012, 05:37 PM
  #368
ScottyP's Avatar
What does the B-Max 2 typically weight out of the box? I've not had chance to get it on the scales and just want to know what to expect.
Do you guys have to add weight to get it to minimum?
ScottyP is offline
Old 06-06-2012, 11:54 PM
  #369
it's about 1020grams/36ounces with a servo installed, with wheels and tires, body and wing. it depends where you're racing, and what type of racing you're doing (stock or modified).
Old 06-07-2012, 12:17 AM
  #370
ScottyP's Avatar
More after a race-ready weight. Limit is 1500gms.
Will try and get mine on the scales tonight.
ScottyP is offline
Old 06-07-2012, 12:50 AM
  #371
check out masami's recent set up on page 18, post#267. you'll see where he has installed weights.
Old 06-07-2012, 02:49 AM
  #372
Scott, i had to put in 15g at the club challenge to get above the 1500g, thats using a shorty pack.
dancurby is offline
Old 06-07-2012, 10:08 PM
  #373
ScottyP's Avatar
Thx Dan. Weighed mine last night. 1515 with low profile Savox, Speedpassion LPF and shorty. Pretty happy with that!
ScottyP is offline
Old 06-07-2012, 10:53 PM
  #374
Shadows's Avatar
Trader Rating: 23 (100%+)
has anyone tried hex conversion for the front wheels?
Wondering if the parts needed for the b4 front hex conversion will work?
thanks
Shadows is offline
Old 06-09-2012, 01:41 AM
  #375
mes
Would be interesting to know! I think it might work, but change the car's steering characteristics...
mes is offline
