Yokomo B-MAX2 buggy thread
#166
You could check if the RB-5 diff or maybe even just the outdrives (UM-515) are a direct fit. At least the bearing size is the same.
#167
Two race days on the new outdrives that I hardened myself and they are already showing significant wear. I don't expect them to last very long. Back to the drawing board. I need to learn Japanese so I can read what they are doing about it in Japan. This has to be a hot topic where more people are running this car.
#168
Ill check with the distributor in Japan during the coming week to see if anything has been advised.
Im looking over the net to see if there is word on it elsewhere.
Cheers
Cheers
#169
i figured out that the b4/t4 tranny and the bmax2 tranny are very similar. the motor plates could literaly be swapped. the tranny cases have very little differences. but it won't fit on the bmax2. the internals (minus the top shaft)could be a whole another story. the whole bmax2 rear end screams b4/t4.
the inside diameter of the outdrive bearings on both the b4/t4 and bmax2 is 10mm. so...i'm going to attempt and try to fit a b4 diff in the tranny. i might have to shim it on both ends.
has anyone figured out if there are any other rear wheels that will fit the bmax2? maybe even adding hex adapters?
#171
I already tried getting the newer b4.1 diff in there. It is too wide and is not a direct fit. The original b4 diff might fit in the tranny case, but then you will have to get a 5/8 bearing in a 15mm hole. Before I start drilling out the tranny case for that I want to try getting an RB5 diff in there. It uses the same bearings at least.
For rear wheels, I've been running TLR 22 wheels using Jconcepts 12mm adapters for the B4, with one HPI 5x7x1.45 axle spacer and two 5x7x.2 shims between the hub and the hex.
#172
#173
After todays racing, can see the out drives are showing wear from the dogbones. Will order a few sets till we hear if yokomo will replace with hardened ones.
On another note, have bought the Reedy short packs and positioned in the middle of tray and what a great balance through the air. Really well levelled, and output of the battery is fantastic for a 4000maH 60C. Plenty of run time and punch for the size!
Cheers
Cheers
#174
good tip on the rear hex adapter. i was thinking about that hex adapter today. is it a direct fit, or is there a bit of play?
i ordered one of the reedy shorty packs as well. bummer that i have to wait til they get them in.
you know after talking to a couple of people, they've had the same experience with the outdrives. i'm thinking that the heat shrink is there to mask the problem, rather than help. i hope yokomo has a solution for this. because it is rediculous.
#175
4WD has.
Cheers
#177
did any of you guys have a rough time putting on one of the thrust washers onto the thrust bolt? nearly making it impossible to slide it all the way down.
