SC10 Velineon
SC10 Velineon
hey guys lets cut it short i bought a velineon system and the shaft dosnt fit within the stock gear cover what gear cover would fit or should i cut the shaft
Either don't use the gear cover, or drill a hole in the gear cover...
DO NOT cut the motor shaft.
Racer53
Racer53
People will cut the shaft and all the little metal shavings get all over the place and possibly inside the motor. You need to put the motor in a bag,poke the shaft through the bag and cut the shaft with a dremel. Should be no issues doing it this way.
Suspended
I have the sc10 with vxl setup and i just drilled a 4mm hole and all is good
Suspended
