1/8 E-buggy Runtimes database >
Old 05-10-2011, 08:21 AM
Pulse_'s Avatar
Default 1/8 E-buggy Runtimes database
Hello,
would like to start a data base on runtimes you get with your setups
Please give your detailed setup (chassis, weight eventually, lipos -mah, C rating, volts-, motor, ESC...)
I think this could be usefull for guys who would like to use the lightest lipos in their buggies during a race
Light = fast
Pulse_ is offline
Old 05-10-2011, 09:26 AM
Orion_2kTC's Avatar
Chassis: Losi 8ight E 2.0
Weight: Unknown (Shameful, I know)
Lipo: Thunderpower 6S 65c 3300 mAh @ 540 grams.
Motor: Tekin 1400kv
ESC: Tekin RX8
Driver Skill: Intermediate
Track Layout: 1/10th layout with sweeping last turn into a long straight.
Driving Style: Slightly convserative. I'm still getting used to this buggy.
Ran a 12 minute main with battery to spare.
Orion_2kTC is offline
Old 05-10-2011, 09:32 AM
Trader Rating: 19 (100%+)
The data I would like to know so it doesn't get skewed by unrealistic claims...
1) Must have actually completed a main. Practice doesn't count. Run times are always longer in practice.
2) How much mah was returned to the battery upon charging
Edumakated is offline
Old 05-10-2011, 09:40 AM
Chassis - Team Associated RC8
Weight - 3.7kg
Li-po - Turnigy 5000mah 20c
Motor - Castle 1800kv
Esc - Hobbywing 80a
Skill - Intermediate
Tracks - Various tracks, all medium 8th scale, dirt or asto
Run Time - Will make a 15 min final easy in the dry, if its too wet then I will hit lvc (3.2v per cell) at around 13 mins.
mikerobinson83 is offline
dj_sparky's Avatar
How much do you think driver skill and style, along with track setup play into the runtimes?
Also, how much power does a BEC draw from the batteries during a 20 minute run? Would an RX pack make up for the weight by saving power?
dj_sparky is offline
Old 05-10-2011, 09:45 AM
Team Tekin
TY@TEAMTEKIN's Avatar
Chassis: Losi 8-E 2.0
ESC: Tekin RX8 ESC Setup
Motor: Tekin 1700 T8 (buggy version)
Battery: Thunder Power 4S 50/100C 5200mAh
Weight: 7.8lbs/3.54kg loaded
Gearing: 18/45
Ran a 15 minute main last year in Spokane, WA with 1 minute of practice before hand. Battery took ~4850MaH and I drove another lap after the race.
TY@TEAMTEKIN is offline
Old 05-10-2011, 09:47 AM
R/C Tech Elite Member
blade329's Avatar
Trader Rating: 114 (100%+)
Originally Posted by Pulse_ View Post
Hello,
Light = fast
Chassis=RC8Be
Weight=*unknown*
Lipo=IP 14.8v 4S 5600mah 40C
motor=Castle 1800kv
esc=Castle MMM
gearing=21/46
I ran a 20 minute main with this setup. It was the Losi Winter Series Rd2 Buggy Novice race. Finished 5th, because I crashed too much. The guy who owns HHH Industries raced with me so he can verify this. I had to drive conservative for the first 10 minutes, then started to open it up a bit. I don't know how much lipo I had left after that.
blade329 is offline
Old 05-10-2011, 10:07 AM
neobart's Avatar
Chassis: TLR 8ight-E EU spec
Weight: 3610g
Gearing: 14/45
Motor: Castle 1515/1Y 2200kv
ESC: Xerun 80A
Battery: Turnigy Nano-Tech 4s 25-50C 4000mah
Mah spent: 240mah per minute.
neobart is offline
