Like Tree5Likes
SC10 4x4 Thread
Old 02-06-2014, 07:18 AM
  #35896
Originally Posted by Cain
Mantisworx doesn't want you to toast your stuff so he is just wanting to make sure you are all setup right.
We all do!
Keep us informed, and if you can get some vid of your runs that would be cool to see too.
I didn't take it as a bad thing. I work in surgery and when we say "finger tight" it's meant that it is tight by hand, not by power.
Believe me, I don't want to toast anything either because I have a hard enough time driving when it's set up right, let alone when it's making a wonky sound.
I appreciate all the help.
Is the spring just a standard AE diff spring or is there another aftermarket on?
Surgetek is offline
Old 02-06-2014, 07:23 AM
  #35897
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
I believe this is the spring you need:
http://www3.towerhobbies.com/cgi-bin...?&I=LXZWK2&P=7
confirm with the factory team manual.
Cain is offline
Old 02-06-2014, 07:25 AM
  #35898
Cool thanks.
I wasn't sure if there was another aftermarket one.
Surgetek is offline
Old 02-06-2014, 11:44 AM
  #35899
Shark413's Avatar
Trader Rating: 24 (100%+)
What happened to Wild Cherry? I haven't seen him on this thread lately.
Shark413 is offline
Old 02-06-2014, 11:47 AM
  #35900
Shark413's Avatar
Originally Posted by Surgetek
I just did it finger tight and then a half turn more. It's not cranked down. I'll give it a try but also just order another spring.
BTW Sharks, I'm taking today at work to read your thread on RCSC.
Surgetek, yeah it's a long read but lots of info and feedback from others related to their experiences with the SC10 4x4.
Shark413 is offline
Old 02-06-2014, 12:08 PM
  #35901
Tech Legend
Cain's Avatar
He's around.
If you look at the new B5 threads he is very active there.
Cain is offline
Old 02-07-2014, 06:35 AM
  #35902
Randidly's Avatar
Ok I am now a believer in the RCShox CDiff, night and day difference at the track last night.
The car was way more consistent that it had been with the VTS, I was making jumps with just a little blip of the throttle that I used to have so much trouble with, just because of the inconsistency of the power.
I am basically running Sharks "Lite" setup at 4.6 lbs with a 8.5T LRP 540 motor "picked it up used for $20", Hobbywing SCT and Reedy 3800 Shorty packs, 6 pins in the diff, plenty of power and punch, actually did a couple of drag races with my buddy who has a Losi with Tekin pro4 4600 and it was almost a dead heat. Loving the truck now I was very frustrated before and actually have a Tekno on order but after the CDiff I might send it back.
My only complaint is the fuzz on the gear from the drilling is there an easy way to clean that up? Not dissing your product, it is what it is, but spent a lot of time getting it ready to run, but it was worth the wait.
Randy
Randidly is offline
Old 02-07-2014, 07:24 AM
  #35903
Tech Legend
Cain's Avatar
do you mean where the diff balls go?
I think on mine I kind of bumped them free with an xacto knife at the time. But confirm with Mantisworx on what he suggests for sure.
Cain is offline
Old 02-07-2014, 08:25 AM
  #35904
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
So how is the SC10 4x4 i was thinking of picking one up or the Tekno.
Anyone know if AE will make a FT Prolite 4x4 in the near future?
RED-LINE M03 is offline
Old 02-07-2014, 08:38 AM
  #35905
Tech Legend
Cain's Avatar
Haven't heard anything on the future of the prolite, I woudn't expect a factory team version of it.
I think the sc10 4x4 is a great vehicle with some quirks.
There is a rumor that a revised sc10 4x4 is on they way so you may want to consider that.
For picking between the two vehicles, I would suggest identify your track conditions and what things you value out of the vehicle.
The SC10 4x4 is killer indoors. its in its element there, especially when you go with a lightweight setup.
Cain is offline
Old 02-07-2014, 08:59 AM
  #35906
fq06's Avatar
In addition to the differences Cain mentioned,
There's a big difference between the two when it come to wrenching as well. The Tekno is a 1/8 layout so its open and easy to wrench on.
The AE is a very unique chassis that takes more time to get to the diffs so your teardown time (or tuning change) is longer.
Both are durable as far as plastics and running into things but the Tekno's driveline is much more durable. Again, 1/8... built to deal with a more powerful motor than what is run in the SCT class.
fq06 is offline
Old 02-07-2014, 09:06 AM
  #35907
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Randy
I was machining the gears from stock pcs and that plastic is not machine friendly, imagine me trying to clean up 100's of those spurs every week!! The V3 will be machined from billet Delrin and will have no burs at all. I will offer a conversion for those that have the V2 as once i start pre-orders the V2 spur will no longer be available. Everything is pretty much ready to go and the new pistons are SICK!! I recently purchased new machines, new software and a different material source. If you thought the pistons were good before wait until you feel the new ones!
Pre-order on the dif and conversion will begin in a few days I STRONGLY suggest that any of you that want one should pre-order. it helps me out and if you dont pre-order the next batch will be weeks away from the first release due to production runs of my other products.
MantisWorx is offline
Old 02-07-2014, 09:31 AM
  #35908
Thanks Guys....
Yes it will be a 100% indoor truck.
What are you guys doing to make it a prolite truck?
Any rumors on the release date of the ver2 sc10 4x4?
Also will my rims work from my sc10.2 on the 4x4?
Many thanks...
Old 02-07-2014, 09:59 AM
  #35909
Tech Legend
Cain's Avatar
Thanks Guys....
Many thanks...
Shark has a great breakdown, basically taking out a variety of uneeded stuff and using a shorty pack up front.
Nothing new on the rumors.
your SC10.2 rims assuming they are hex will work. +3mm offset rims are popular.
Cain is offline
Old 02-07-2014, 02:51 PM
  #35910
Shark413's Avatar
Thanks Guys....
Many thanks...
Once you go lite you will never go back. It is much easier to go lite than it is to go heavier. To go lite you basically remove stuff. The SC10 4x4 is already pretty light, so if you remove the nerf bars, replace the huge rear bumper with a RPM skid, remove belt covers, etc. and go with a shorty pack you will lose a lot of weight. And please ignore the Exotek chassis in the pictures and use the stock chassis (which is lighter) when you go lite.
The shorty mod only requires one extra hole in the chassis, and the stock stick pack battery holder.
I used the FT saddle pack hold down hardware and a scrap piece of CF (you could use aluminum, plastic, whatever to make a battery strap).
I just added notches in each end that work with the saddle hold down hardware, and they screw into the forward nerf bar mounting holes.
RTR 5lbs 4.2oz
Stock plastic chassis with the forward shorty mod using B4.2 thumb screws.
Shark413 is offline
