Like Tree5Likes
SC10 4x4 Thread
Old 01-31-2014, 11:13 PM
  #35866
Originally Posted by hip137
is there an under body out that fits the ft kit ?
Any sct body, Jconcepts and proline being the most popular.
lee111m is offline
Old 02-02-2014, 06:43 PM
  #35867
Trader Rating: 129 (100%+)
Has anyone tried the Trackstar 550 motor and Hobbywing or Trackstar esc? Been using a Castle 3800 system so far. Want to try an affordable sensored system.
Thanks for any help.
Links
http://www.hobbyking.com/hobbyking/s...550_size_.html
http://www.hobbyking.com/hobbyking/s...nsorless_.html
cdlowe30907 is offline
Old 02-02-2014, 08:20 PM
  #35868
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Yes...
Links
The Hobbywing combos are killer!
http://www.falconsekido.com/products...sct-pro-series
I personally have ran Combos: SCT-PRO-C1 (4700KV Version) & SCT-PRO-C2 (4000KV Version)
The performance of either combo is amazing!
The 4700 version is a bit much for the SC10 4x4 unless you are on a big outdoor track, other wise I would go with the 4000KV combo.
Good Luck!
Alan
JFuel11 is offline
Old 02-03-2014, 06:03 AM
  #35869
I'm getting a high pitched squeal when I punch it. It's not there when I am driving at a constant speed but when I really goose it on the straightaway it does it. It doesn't do it when it isn't under a load either. On a stand with the wheels free it's fine.
I thought maybe it was the belt in the front but it sounds more in the rear. I checked the spur and the pinion and both seem fine. The motor is nice and tight.
It could be the motor, but I can't think of what that would be.
Any suggestions?
Surgetek is offline
Old 02-03-2014, 07:04 AM
  #35870
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Probably the best in my opinion would be the outerwears filter for the sc10 4x4. I don't see why it wouldn't work as its not a hard lexan material, but repels water and dirt, but lets the chassis "breathe". i really enjoyed mine for what it is when I had it. pricey, but I felt worth the money.
Any suggestions?
can you take a vid?
Cain is offline
Old 02-03-2014, 08:02 AM
  #35871
can you take a vid?
I can later.
It's not constant. As soon as you lay off the gas, even the littlest bit, it's gone.
Surgetek is offline
Old 02-03-2014, 10:25 AM
  #35872
Shark413's Avatar
Trader Rating: 24 (100%+)
I can later.
Slipper issue? Could be that under power the slipper is slipping too much causing the sound and when you lay off the throttle the slipping/sound stops? Are using a VTS, original or aftermarket slipper?
Shark413 is offline
Old 02-03-2014, 10:45 AM
  #35873
I have a center diff
Surgetek is offline
Old 02-03-2014, 05:29 PM
  #35874
fq06's Avatar
Sounds like the diff is slipping under high loads. Can't think of anything on that truck that might make a sound like that other than a ball diff that's slipping.
Are the spring coils kissing? I think in a previous post you said they were but didnt go back to look, sorry.
Maybe a new spring, especially if you have the older spring and not the vts spring. Even if you have the more HD vts spring, they fatigue over time.
Do you have at least 6 pins? Sorry, again didn't scroll back a page or two.
fq06 is offline
Old 02-03-2014, 06:54 PM
  #35875
Shark413's Avatar
+1 on what FQ06 said. I assume your talking about the RCShox center diff which is a big ball diff. The spring needs to be almost completely compressed. It is basically an over sized ball diff and they "Bark" when too loose. Barking is the sound ball diffs make when they slip and is very bad. The sound you are hearing may be your diff slipping.
Here is my RCShox center diff, note how compressed the spring is. Please ignore the stripped spur the topshaft bearings blew out and caused a bunch of slop that ended with a stripped spur.
Another view of the center diff and spring.
Shark413 is offline
Old 02-03-2014, 06:59 PM
  #35876
Shark413's Avatar
Here is a more current picture of my cDiff, again noticed how compressed the spring is and how much thread is showing outside of the locking nut.
Shark413 is offline
Old 02-03-2014, 07:52 PM
  #35877
TommyJoe's Avatar
Yeah I ran the 5.5 turn version of that motor with the TrackStar 120A sensorless esc and it was a great combo. But the can was soft and I ended up stripping the mounting holes (all 6 of them). I bought a sensorless Tenshock 4400kv to finish the outdoor season and was very pleased with it's performance as well. When I started running indoors in October I bought the TrackStar 120A turbo esc and the TrackStar 540 4 pole (4250kv). It lightened up the rear end of truck considerably and it's more powerful than necessary for a tight indoor track.
TommyJoe is offline
Old 02-04-2014, 06:23 AM
  #35878
I'll check it out. The first thing I thought to look at was the front. I can't remember if I opened up the center. I believe I only have 4 pins in it. My friend built it and got the diff for it then sold it to me to get a Losi. I'm still learning it.
Surgetek is offline
Old 02-04-2014, 06:57 AM
  #35879
fq06's Avatar
Check the spring setting first. If its cranked down like sharks pic, you may need to tear into it.
I would pick up the newer vts spring if that's not what your friend has in there, that alone could be it.
Below is a walk through on assembly, black grease for the thrust bearing and regular diff grease for the balls. 6 pin is the most common for a track with good traction. Low traction 4 pins would be good.
I ran 6 or 8, 8 if traction was really good that day.
http://www.rctech.net/forum/10600508-post878.html
fq06 is offline
Old 02-04-2014, 07:11 AM
  #35880
Thing is its running great. I didn't do anything new to it,. Just took it off the track for a battery change and then it started and like I said it's not all the time and not every time.
Surgetek is offline
