Like Tree5Likes
SC10 4x4 Thread
Old 05-25-2013, 02:22 PM
  #34216
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Originally Posted by Ranger411
Yup RC Shox. I bought fq06's 4x4 the note he had about running outdoors was to throw the 2 stages on and add 5 wt to the oil. Figured he knew the truck better than I do. I have some Losi 32.5 wt, you suggest I try that next time I swap oils or the problem continues?
if could be the pistons he is using may be different that what comes stock from RC Shox? I know some guys were drilling them out.
You may want to confirm with him.
For me personally, for a loose track setup I was down to 27.5W Losi front, and 22.5W losi rear with the stock RC Shox dual stage pistons, I was also running the exotek chassis and center diff, Blue Fronts on front, Green Fronts on Rear.
Good thing though is that an oil change is pretty quick in comparison to changing diff fluid on the sc10 4x4
Cain is offline
Old 05-25-2013, 02:23 PM
  #34217
Tech Legend
Cain's Avatar
Its going to warm up in the next few days again anyway so I have another question.
Which would be better for a small to med size outdoor track, the Tacon 4 pole 4800kv I have been using or a Tekin Redline SC4X 5.5T that I just picked up cheap and have yet to use?
based on kv alone and the fact that gearing range on the sc10 4x4 is a bit more limited, I believe the 5.5T would be better on a small to medium size track.
This is basically similar to how I felt with the Tekin Pro4 4000Kv versus the 4600Kv.
Cain is offline
Old 05-25-2013, 02:37 PM
  #34218
Ranger411's Avatar
Trader Rating: 29 (100%+)
Is losi fluid thicker than Associated? I only have 32.5 Losi but have 25, 27.5, 30, 35, and 40 wt Associated. Blues in front like you, Yellow rears in back, its feels pretty slugish. I have green fronts lying around will give them a try sometime.
Ranger411 is offline
Old 05-25-2013, 03:21 PM
  #34219
Tech Legend
Cain's Avatar
I use this chart and another (can't find it right now) for oil comparisons:
Cain is offline
Old 05-25-2013, 03:26 PM
  #34220
Tech Legend
Cain's Avatar
Also, for me personally I found I liked the front springs on the rear on bumpy sections as the suspension reacted faster. Before that, I felt like the vehicle was diving into the ruts.
Cain is offline
Old 05-26-2013, 08:21 AM
  #34221
Tech Legend
Wild Cherry's Avatar
TRCR's NEW LAYOUT
http://www.youtube.com/watch?feature...v=CVGIbixe8lA#!
Wild Cherry is offline
Old 05-26-2013, 08:54 AM
  #34222
fq06's Avatar
To caveat that, for outdoor I went up in spring rate as well as oil if needed. I ran 2 stage all the time but had tried standard pistons on my last run which is how you recieved it. I ran thicker oil 2 stage compared to standard.
Sometimes it was really blown out and bumpy if it hadn't been maintained in a while. And when it was brutal I would make the shock & spring changes.
I also raised the ride height a mm or two.
All done in California where temp changes are not that drastic
Like Cain said though, easy to change fluids, play with it and see what works for you
fq06 is offline
Old 05-26-2013, 08:57 AM
  #34223
ovalosi's Avatar
Trader Rating: 55 (100%+)
Originally Posted by Wild Cherry
looks fun you in this wild cherry?
ovalosi is offline
Old 05-26-2013, 08:59 AM
  #34224
Tech Legend
Go back to the 1.2 piston and use Ae 35w for front & Ae 30w weight on rear, yellow springs all around .
You will find a big improvement in performance...
Old 05-26-2013, 09:01 AM
  #34225
Tech Legend
Naw , I made the A and did not strip a spur gear like my team mate Cantrell in the yellow submarine... Ha !
Old 05-26-2013, 09:07 AM
  #34226
MantisWorx's Avatar
Trader Rating: 28 (97%+)
It was 40 wt front, 35 wt back with 2 stage pistons. I guess it was a learning experience as it will be back in the 80s by the end of the week. Shocks feel real sluggish in the cold basement now that you mention it.
40/35 is too high even when its hot, the 2 stage pistons will overpack with oil that high. 35 in the front is max you should need but most tend to stay in the 32.5/30 front and 22.5/27.5 rear. unless they were drilled out.
MantisWorx is offline
  #34227
fq06's Avatar
Disagree with piston and oil recommendations, 2 stage is superior outdoor.
Problem was 40 temps, get back to normal temps (sounds like NY is) and it will be dialed again.
I had built a brand new set of FT shocks with stock pistons the last day I ran it (one pack) just to try something different and was on the fence indoor. Not enough time for me to have decided. But without a doubt 2 stage build is best for an outdoor track.
fq06 is offline
Old 05-26-2013, 09:10 AM
  #34228
Ranger411's Avatar
It will be back to 85 this weekend in conditions were it ran well. I am going to do the motor change that I talked about and just the spring changes this week. This is good learning for when we try to squeeze the last weeks in the Fall.
Old 05-26-2013, 09:11 AM
  #34229
fq06's Avatar
What's up Marcus!
Ha Ha! Yeah, I always ran higher weight than you advised. But it worked well for me. When Ranger ran it during normal temps, he liked it. Temp change was the issue.
Our oil weight differences could also be the weight of the truck. Exo chassis and a number of aluminum parts upped the weight but it was very stable for a sc10 4x.
But it only takes a few minutes to change fluids so try a range of weights on a practice day as see what suits you best.
Happy wheeling Ranger
fq06 is offline
Old 05-26-2013, 09:53 AM
  #34230
Tech Legend
Ranger
Sharing my experience with temperature & shock oil ...
Only consider changing when the temperature has dropped to 45 degrees.
Even then only lower the oil by 1/2 weight .
If temperatures drops to 40 or below ?
Then go a whole weight down .
