Like Tree5Likes
SC10 4x4 Thread
Old 03-30-2013, 09:39 PM
  #33586
I just bought the tekin rx8 with the pro 4 4600kv 1y today.. i was at a track with med-high traction and my truck would pick up speed soo fast it would gradually lift the front end... I would like to put my truck vs your truck on a back stretch...
racer_rick is offline
Old 03-31-2013, 12:00 AM
  #33587
Tech Legend
Wild Cherry's Avatar
Ae domination .....
All possible because of the Team ....
Wild Cherry is offline
Old 03-31-2013, 12:43 AM
  #33588
cantrell8's Avatar
george do you have the drill bit for the grub screws?
cantrell8 is offline
Old 03-31-2013, 06:03 AM
  #33589
Suspended
dominick i.'s Avatar
Trader Rating: 123 (97%+)
go with the lrp flow with the fan.
i had that in mine with a reedy 550 4.0 12t pinion and it never got hot.
island raceway hobby had tons of traction and it didnt get hot at all. Won my first a main in 4wd sct there back in dec. never should have sold it.
new one on the way
dominick i. is offline
Old 03-31-2013, 07:05 AM
  #33590
sugs's Avatar
Originally Posted by Wild Cherry
Nice work Casey..
We had to install a fan , Havoc therma 1st qualiflier..
Let you know if it's the cure...
Bet that 8 won't need a fan...
Bummer about the Havoc, I had been thinking about trying one. The new Pulse is the same size, I wonder if it has more power capability.
sugs is offline
Old 03-31-2013, 07:08 AM
  #33591
drolmaeye's Avatar
Default Havoc thermal?
I'm surprised to read posts about the Novak ESC getting too hot. I've had a Novak Havoc Pro SC (first X-drive version, with button on the on/off switch lead), together with their 4.5 550, since I built my truck a year ago. I've geared every pinion from 12/62 to 15/62, ran indoors and outdoors, and never had it thermal (even when running longer than our track's race times). At some point it was starting to get warm so I went with the fan and never had a problem (running something like nanotech 65C 5100 mAh saddles).
All of this to say, if you are baking this ESC maybe double check the usual moving parts for binding, etc.
drolmaeye is offline
Old 03-31-2013, 07:48 AM
  #33592
Tech Legend
I was bummed as well
The LRP FLOW & Reedy 550 4.5 I use gets around 140 and I do not even use a fan...
Using the Novak 550 4.5 and the FLOW truck came in at 160 with no fan .
So we installed the fan to help lower the temperature .
Maybe the motor was the issue ?
Cantrell , no I borrow Brownies drill & tap ...
Old 03-31-2013, 08:01 AM
  #33593
Trader Rating: 57 (97%+)
Just fit the activ8...He is using the plastic center chassis right?
CaseyDDR is offline
Old 03-31-2013, 08:02 AM
  #33594
Tech Legend
We have the lrp FLOW in it now , no problems with fit or what ever ...
Old 03-31-2013, 09:49 AM
  #33595
I was wondering how much weight is everyone running in the front by thier servo.
I tried none at first, then went to 1oz and now there's 2oz and it seems to drive and jump alot better.
rippen is offline
Old 03-31-2013, 09:53 AM
  #33596
Tech Legend
Use the weight on the nose to control or smooth out the steering entering the turns.
Usually done when traction comes up to med high ...
Old 03-31-2013, 09:56 AM
  #33597
I already know what your saying, but how much do you run, thanks.
rippen is offline
Old 03-31-2013, 09:59 AM
  #33598
Tech Legend
Use no weight med traction
as traction comes up can go to 1/2 oz on each side of servo .
More grip ? ( extra med high or using slicks ) use 1oz to 1 1/2 oz on each side .
Old 03-31-2013, 10:05 AM
  #33599
That's what I was wondering, how much is to much
I've seen guys @ my local track that are running 2-3oz's on each side and it's a blue groove high bite track.
rippen is offline
Old 03-31-2013, 03:43 PM
  #33600
Tech Legend
not sure bout 3 oz, that's a lot of weight.
Try 3 oz , should be able to feel how the steering is affected by additional ballast for fun.
