SC10 4x4 Thread
I use the exotek rear hubs last sunday and matched up the spacers on the bulkhead exactly to the hubs and it worked fantastic. I won the Losi infested A main with that adjustment. The truck really woke up and rotated very well in the corners, even with using the front overdrive pulley. Other than a sway bar adjustment, the kinwald setup really works on an indoor clay track.
And not to make this an exotek advertisement, but the steering rack worked really well too.
I'm gonna cross my fingers and attempt to run this truck outdoors in the spring.
can you try something dominic since you have the exotek carriers as it would be quick adjustment?
Can you try the following:
- Lower the amount of spacers under the carrier only, note what you see
- Lower spacers under inner ballstud and hub, note what you see
- Lower spacers under inner ballstud but raise on hub, note what you see
I would say do this in a significant manner (say 7mm versus 1mm, etc), I was going to see about doing this myself in some fashion on carpet to confirm a few things but no longer have the vehicle.
i've previously ran the inner link 2mm lower than the hub carrier and the truck squared up just fine, but it rotated better when the link heights were equal regardless of height. I try to focus on forward momentum on all of my rc vehicles, and those exotek hubs have helped create corner speed with the tuning option of height adjustment( I even put exotek hubs on my sc10 2wd for that adjustment as well)
Just remember, not everyone slows down before the corner and drives through them under power, they usually stand on the brakes mid corner and wonder why when they accelerate out of a corner the truck is loose. The anti squat doesnt do squat when a truck is gliding into a corner, you gotta be either on the brakes or accelerating.
On the plus side, I ran some pretty quick 2wd laps, and had a blast. It was dialed. Finished the day off with happy hour tacos and beers. A bad day of rc is still better than a good day at work?!?!
So I was going thru my parts and saw that I had some shims and b44 aluminum hub towers. Can I use the b44 hub towers for the 8mm mod? I thought I saw somewhere someone use these?
Also the I found some 3/16 axle shims and was wondering if I could use these to shim my gear diff?
Found this thread a month after picking up the SC10 4x4 when it first came out. I know from following this thread that most of the original people who spear headed all the tech on the original version of this truck have moved on. All of them had the smarts and know how to take this kit truck from a highly anticipated over hyped poor attempt of a short course 4x4 to a half way decent performer. The Mac the knife clutch baskets, rear top shaft pinning, RC Shox garo discs, center diff, dual stage pistons and AKbar ackerman steering bar, carbon fiber chassis braces, replacing warped arms, saddle pack conversions, front springs on the rear, 8mm rear mod, Exotek chassis and more I have tried all in the hunt to get this truck to drive better. All these mods were due to the guys smarter than me on here at rctech. I have said in the past that AE owes credit to their FT version of the SC10 4x4 to guys on this thread. They won't say but I will. Thanks guys for all your help. It was frustrating and fun but like others it's time to move on. Well finally sold my SC10 4x4. Posted it today and it sold in about 2 hours.
5Likes
