Like Tree5Likes
SC10 4x4 Thread
Old 09-14-2012, 09:23 PM
  #29656
Maddog94's Avatar
Trader Rating: 44 (100%+)
Originally Posted by fq06
Center diff, FTW!!
+1. The Center Diff makes this a completely different truck (in a good way). Highly recommend!
Maddog94 is offline
Old 09-14-2012, 09:48 PM
  #29657
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
+2
Cain is offline
Old 09-14-2012, 10:28 PM
  #29658
Large Outdoor Track - Center diff FT-motherfkn-W
Indoor tight Track - VTS proves superior in my truck.
Again, relating to how you drive and whatnot. All of this is opinion based.
SC Shaun is offline
Old 09-14-2012, 10:32 PM
  #29659
fq06's Avatar
Originally Posted by ilanstylz
You ever gonna upgrade to 2.4ghz??
Honestly the price tag for the mt4 to me is well worth it over the spektrum, like others have already stated...... The spektrums are known to have interference issue's as well as they don't mix well with high voltage servo's like savox etc......... Another good option is the Futaba 4PL its what I switched to from spektrum and I would never switch back
Yeah, just this week. Finally gave up running the M8 or JR xs Fm radios
Still find myself seeing a ghost antenna and tilting the radio to the right when I'm on the left side of the track & vice versa. Old habits die hard
A lot faster than the M8
fq06 is offline
Old 09-14-2012, 11:09 PM
  #29660
xDIRTYx's Avatar
I got bored tonight and decided to give an idea I had a shot. This body is about 1 more day at the track away from being trash. What do you guys think?
xDIRTYx is offline
Old 09-15-2012, 02:40 AM
  #29661
Trader Rating: 6 (88%+)
Can this kit use hardcase lipos or saddle packs only?
Ironwolf1974 is offline
Old 09-15-2012, 02:53 AM
  #29662
Smithy79's Avatar
G'day everyone,
Been ages since I've posted but I read the thread every night. Never seem to leave cause I never log out from my iPhone. I'm always in the 'online users' tab. LOL.
Sought of off topic in regards to the SC10 4x4, but I've found the last few posts regarding radios quite interesting.
I'm looking to upgrade my tx soon and I think you've all helped with my decision of the MT4 as my next radio.
Please don't laugh at me but my current radio I use is the traxxas link 2.4GHZ from my Rustler. It's all I know, cause I've only been in the hobby for 2 yrs. I run the traxxas link in all my vehicles. MBX6 ECO, SC10 4x4, & DEX210.
Very noob question as like I said its all I know and I'm used to, but what can I expect to find in the change to a better radio system? It's gonna be a huge learning curve, as I'm used to just 2 trim knobs and a throttle trigger..and steering wheel of course.
I've only just started racing locally here with the SC & pulled 2nd in the AMain on my first night.
Cheers for reading guys.
Smithy
Smithy79 is offline
Old 09-15-2012, 02:59 AM
  #29663
Trader Rating: 18 (100%+)
It can be setup to use either style battery.
xxxntwv is offline
Old 09-15-2012, 03:01 AM
  #29664
So the FT kit I can set it up during the build for either?
Old 09-15-2012, 05:29 AM
  #29665
Maddog94's Avatar
Yep! I personally use stick packs. But the hardware comes in the Team Kit to also convert to saddle pack use. Everything you need to do either.
Maddog94 is offline
Old 09-15-2012, 09:02 AM
  #29666
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
On indoor I run the Center diff with believe it or 3 pins and it seems to work good. Next time I go out I'm going to add 3 more and see what happens.
JEFFs SC10 is offline
Old 09-15-2012, 09:05 AM
  #29667
Tech Legend
Wild Cherry's Avatar
Gluing my Sc10 chassis ft & back clip's and the rest all together .
Making it stiffer...
Wild Cherry is offline
Old 09-15-2012, 09:55 AM
  #29668
fq06's Avatar
Originally Posted by Smithy79
G'day everyone,
Smithy
I'm not familiar with the traxxas radio, but if your only adjustments are knobs the MT-4 or any other decent radio with a LCD screen and digital adjustments will be far better than what your used to.
End point adjustment to set your left and right steering maximum throw to make the car turn the same size circle L & R and also to not be exceeding the physical steering stops stressing the servo.
End point adjustment for the braking channel, you can dial back the max amount of brake when your trigger is full brake. Kind of anti lock braking, set it just to where you barely skid at full brake. Can be adjusted on the drivers stand with one of the hot buttons to fine tune or when traction levels change.
Exponential to soften the initial movement of the steering, throttle, brakes.
The list is very long.
On of the biggest improvements will be the speed that the car reacts to the radios signal.
I never really felt that my radio was slow... till I picked up a new school fast response radio... man was my radio slow in the time it took to steer when I turned the wheel or applied throttle or brake.
Telemetry, not sure it's needed, haven't really played with the temp function. The telemetry rx is double the price of the regular rx is so I got the regular rx for my xxx-4. But since it comes with a telemetry rx I will at least mess with it in my AE and see if it's close to accurate. Or even consistent. If it consistently reads 140 when the temp is actually 160, that's fine I know what temps to look for when practicing.
Ton of radio choices out there, I have had airtronics for years and like their products. The MT-4 seems to have all the bells & whistles that the other extra large behemoth radios have in a nice light standard size package.
EDIT:
Temp sensor is now attached, will check that function out the next time I drive.
fq06 is offline
Old 09-15-2012, 10:14 AM
  #29669
CraigMBA's Avatar
Trader Rating: 22 (100%+)
I've been painting the murdered out thing for a while. It's a little tough to make it not look ghetto unless you go to a bunch of trouble to mask it twice. Yours looks okay.
Funny enough, I have four (new) sedan bodies trimmed and mounted awaiting a similar fate.
CraigMBA is offline
Old 09-15-2012, 10:26 AM
  #29670
fq06's Avatar
Thumbs up
That's dope
fq06 is offline
