Like Tree5Likes
SC10 4x4 Thread
Old 08-28-2012, 08:29 AM
  #28891
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I'm running yellow fronts and yellow rear springs , feels good . What would be the benefit of running blue fronts in the rear? I'm on indoor tight clay, smooth, medium traction. Is this used more often for large outdoor??
ryanpatrickgore is offline
Old 08-28-2012, 08:32 AM
  #28892
Tech Legend
Wild Cherry's Avatar
ft blue spring is two or three steps firmer than yellow rear
Wild Cherry is offline
Old 08-28-2012, 08:39 AM
  #28893
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Ryan,
I tried both and the blue front felt better. Seemed to me like the rear was planted more. I went back and forth several times and always felt like the blue fronts in the rear were more consistent.
Wildcat1971 is offline
Old 08-28-2012, 08:50 AM
  #28894
Hmm. Ok. I feel like my truck is kinda loose and it wants to roll around back and forth in the corners. I got 8mm, it's not flipping. But feels soft and could be a bit more stable. Maybe a stiffer sway bars or springs??? Whadda ya think
Running the Cody setup right now.
Old 08-28-2012, 08:53 AM
  #28895
Tech Legend
Do you think your traction will improve with a stiffer rear spring ?
Old 08-28-2012, 08:57 AM
  #28896
My traction improved in the rear with the blue springs. I tried to go softer for more rear traction, but it had the opposite effect. Kinda weird, but that was my experience. I had the team kits, so I already had them. Borrow a set and try it out before you buy. Several people just get the front spring kits and fine the spring that works for them.
Old 08-28-2012, 09:14 AM
  #28897
Not really traction I'm looking for. It just feels soft like it wants to roll, And it's loose. Like it takes more time to square up outta the corners. I had trouble hitting the trippel the other night, right after that left hand 90* corner. I'm thinking maybe stiffer but I don't want to loose traction.
Old 08-28-2012, 09:16 AM
  #28898
I did just come off of a 2 week b4.1 buggy spree. Which drives like a dream for me. Maybe I'm just spoiled by that and I'm missing the stability of it.
Any tips?? Or suggestions
Old 08-28-2012, 09:19 AM
  #28899
Tech Legend
stiffer spring on rear ?
will improve forward bite
less side bite though
less chassis roll (less steering)
jumps & landings improve
My tip for you ?
Slow down more before entering
corner for triple in ft of driver's stand ...
We need to show these guys how
technical our new layout is ...
Old 08-28-2012, 09:24 AM
  #28900
Maddog94's Avatar
Trader Rating: 44 (100%+)
I thought rears were supposed to be a bit softer than the fronts?
Maddog94 is offline
Old 08-28-2012, 09:26 AM
  #28901
fq06's Avatar
One of the main indoor benefits to the center diff.
I couldn't resist
fq06 is offline
Old 08-28-2012, 09:28 AM
  #28902
Tech Legend
Question for Cameron K ....
Been a while , but would like your opinion of the steps & the sizzor jumps on the Show Down layout ?
I had a big hand in the making ...
Old 08-28-2012, 09:30 AM
  #28903
Tech Legend
blue ft is stiffer then the rear red ...
Old 08-28-2012, 09:54 AM
  #28904
superslow's Avatar
make sure your not diffing out. check your diff oils, maybe add some weight like kinwald in front of the servo
superslow is offline
Old 08-28-2012, 09:56 AM
  #28905
superslow's Avatar
im running a tekin pro 4 4600 with a 62 spur, and a 12 pinion. i should go up to a 14? pretty big outdoor track? i have looked at all the factory driver set up and they are around a 12-13.
