Like Tree5Likes
SC10 4x4 Thread
Old 08-11-2012, 10:12 AM
  #28186
vito's Avatar
Originally Posted by Wild Cherry
Are traction rolling over Vito ?
no
vito is offline
Old 08-11-2012, 10:14 AM
  #28187
vito's Avatar
http://prolineracing.com/short-cours...tires-trencher
vito is offline
Old 08-11-2012, 10:17 AM
  #28188
vito's Avatar
i cant get them to stay guled well on jc rims my gule sucks tips?
vito is offline
Old 08-11-2012, 10:21 AM
  #28189
Tech Legend
Wild Cherry's Avatar
Originally Posted by vito
no
Good ....
Have you tried the bigger pinion yet for more speed ?
If you used bad glue ?
Take um off & use tire glue
Wild Cherry is offline
Old 08-11-2012, 10:25 AM
  #28190
vito's Avatar
Good ....
iam gooing to pick one up 15 to try
the gule was new it was 3 sc
vito is offline
Old 08-11-2012, 10:33 AM
  #28191
Tech Legend
Buy some glue designed for tires Vito ,.
Losi tire glue is used by almost everyone , standard or thin..
Old 08-11-2012, 10:41 AM
  #28192
fq06's Avatar
Standard (medium) tire glue is easier to glue with to start out, takes longer to set, gives you more time. Tire glue only like wc said. Rims & tires are too expensive to not use the correct glue on.
Scuff up the channels on the rim that the tire sits into, scotch brite or other.
fq06 is offline
Old 08-11-2012, 11:09 AM
  #28193
Also scuff the tire itself along the glue edges.. most tires are still covered in the remains of the stuff they use in the molds to prevent the rubber from sticking to the mold. If you don't take that off, it also keeps the glue from sticking to the rubber. I use a dremel with a sanding drum to lightly roughen up the areas to be glued, works great and I have never had one come off when doing that.
Arakon is offline
Old 08-11-2012, 11:10 AM
  #28194
Originally Posted by samuelsonmark71
Everytime I read these posts with the garbled english translation I want to remove my eye balls with a plastic spoon...
Originally Posted by Wildcat1971
don't be insulting, just put him on ignore if you dont like it.
"ignore" FTW... now if you all can stop quoting him...
9T
Maybe elleit can dive truck fast twichy , but if he had to dive with me with all that twich ?
wood loose 5strate times .....
LOL... If you can't beat em join em, eh WC?!
Sofa King is offline
Old 08-11-2012, 11:51 AM
  #28195
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Use rubbing alcohol on a qtip and wipe down the tire and wheel where the 2 surfaces are to meet. Let air dry then glue. Lots of residue on stuff from factories. You can scuff the wheels with sandpaper if you want. Not the rubber tho
ryanpatrickgore is offline
Old 08-11-2012, 12:40 PM
  #28196
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I use the blue stuff. Reallt thin. Fine tip thought
Wildcat1971 is offline
Old 08-11-2012, 12:44 PM
  #28197
i find if you properly clean the tire and rims most super glue works fine.
twisted is offline
Old 08-11-2012, 12:49 PM
  #28198
I just wash them with warm water and a light detergent. At the track alcohol is fine. You want a thin glue that will flow into the bead
Old 08-11-2012, 12:56 PM
  #28199
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
Taking the SC 4x4 to it's last race tonite.. Bittersweet moment for me really. This truck has come soo far from where it started, and I hope to send it off with a smile tonite. I Was just doing a pre-race check and discovered my v2 spur was installed backwards prior to last race!!! As a note to folks,,,, make sure the pins trail the balls!!!! Maybe why she was a lil off last time out.. Anyway, would like to thank the good people on this thread. Without the knowledge here I would have never gotten the AE handling so good!!!!!!!
SOuthernFRIED is offline
Old 08-11-2012, 02:34 PM
  #28200
Are you changing trucks or not going to run SC4X4?
RossNZ is offline
