Like Tree5Likes
SC10 4x4 Thread
Old 04-13-2012, 11:33 PM
  #21421
murky123's Avatar
I thought that a spool would lock up your left and right tire. giving the inner and outer wheel in a corner the same cornering speed.
for fast cornering you want you inner wheel not at the same speed as your outer wheel.
how thicker my diff fluids, how harder to steer. so a spool would be like the thickest diff fluid, right?
if im wrong, plz correct me
murky123 is offline
Old 04-13-2012, 11:42 PM
  #21422
Tech Legend
Wild Cherry's Avatar
in my experience u find more steering thicker you go in ft
Wild Cherry is offline
Old 04-14-2012, 04:30 AM
  #21423
Evil Genius jr.'s Avatar
Trader Rating: 28 (100%+)
Running at Awesome tomorrow? I'll be interested in how it runs and what your set up is.
no, I'm going to ECH. Last weekend it ran like crap at Awesome so you don't want my setup lol
Evil Genius jr. is offline
Old 04-14-2012, 07:26 AM
  #21424
rbcts's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Cameron Kellogg
A few people have started getting the v2 center diff and have had questions regarding the installation. I have done a little how to installation guide on the RCShox thread. Link below.
http://www.rctech.net/forum/10600508-post878.html
That's awesome! Really appreciated!
rbcts is offline
Old 04-14-2012, 07:57 AM
  #21425
hlpressley's Avatar
Trader Rating: 209 (99%+)
With the addition of the FT upgrade kit how much difference is there between the Team and the FT truck? I know the shocks are different as well but are they better?
I bought this truck to race on Friday nights at a small outdoor track. It doesn't have any large jumps and I am not interested in running the SC Nats anytime soon. With that said I am puzzled at how many of these upgrades I will actually benefit from. I race 1/8 most of the time at large outdoor tracks and when I am there the SC10 will be at home. Just looking for something to have fun with on Friday nights but I have to admit after driving it last night for the first time it was a hand full to say the least. Very different than anything I am used to with 1/8 nitro or electric buggy. The truck seemed VERY on edge and never planted. Is this normal?
Thanks in advance for any and all advice. I am a SCT newb!!
hlpressley is offline
Old 04-14-2012, 08:33 AM
  #21426
ilanstylz's Avatar
Trader Rating: 142 (100%+)
I don't think the shocks are better from the FT kit, what will make them better are either two stage pistons from rcshox or possibly even MIP's new bypass system..........The only major upgrade necessary IMO if you want to upgrade more to the FT version is the new clutch setup or the center diff from rcshox..........
Are you running swaybars? If so which ones front and rear as well as what springs front and rear?
You can also look into getting the exotek chassis or adding weights to lower the COG as well as balance it out better, as well as by adding inline saddle pack conversion will help also........
ilanstylz is offline
Old 04-14-2012, 08:36 AM
  #21427
Tech Legend
[QUOTE=hlpressley;10601537]With the addition of the FT upgrade kit how much difference is there between the Team and the FT truck? I know the shocks are different as well but are they better?
Great choice for your new ride Pressley.
Team shocks come with a Teflon coating which makes for smoother shock action . Otherwise they are same as the blue standard shocks ...
The new conversion kit provide the latest upgrades from Ae, new V2 slipper performs way better than the old original slipper , the Ae chassis brace is the best bar none .. Both parts offer a big performance increase compared to the original Sc10 4x4 kit....
You may need ft & back sway bar's
Your truck should not be hard or difficult to drive , suggest you review the Team set-ups available on www.rc10.com . Pick the set-up closest to your track conditions..
Also have someone with experience drive your ride and help you...
A big short cut towards gaining speed & mass fun ...
Get to
paint me new body today , got the JConcepts High Flow...
Should get to run it tonight ,. Look out ! Pink on the track soon ..
Old 04-14-2012, 09:10 AM
  #21428
hlpressley's Avatar
Thanks for the help guys. I do have the sway bars installed but will have to check to see which ones they are. As for springs I believe they are blues and yellows? I will double check that as well. I did add some lead to the slots along the side of the chassis (3 oz.) total was all I could fit. It did seem to help but I think it may need more of where that came from.
As of now I do plan to buy the FT upgrade kit and switch over to saddle packs as all of those upgrades seem to make sense to me. The whole belt drive thing has thrown me for a loop. !/8 buggies have shafts and a center diff.
Thanks again for your help guys!
Old 04-14-2012, 11:15 AM
  #21429
nmdesertracer's Avatar
Trader Rating: 59 (100%+)
The best mod so far to my truck was the rcshox center diff and v2 shock pistons!!
nmdesertracer is offline
Old 04-14-2012, 12:14 PM
  #21430
n8b
Trader Rating: 126 (100%+)
Default FT SADDLE PACK SIZE?
I'm thinking about picking up the Track Power 5400 60c lipo pack or maybe the Turnigy 5100 65c nano-tech packs for my new Factory Team truck. Would the orion 90c be any better? I'll be powering a RX8/PRO4 4000.
Does anyone have these in the FT setup? Is there any height restrictions with the FT saddle setup?
Nate
n8b is offline
Old 04-14-2012, 12:51 PM
  #21431
I tried fitting some tall saddles to mine this evening and they went under the belt tunnel fine but the battery strap wouldn't do up due to the screws all being to short to hold it down. Solved with longer M3 bolts but the FT ones are to short.
Beachbuggyphil is offline
Old 04-14-2012, 01:51 PM
  #21432
R
Nate
ac
the only saddles i would buy right now is the proteck 5300 70c, the gens ace arnt bad either but im pretty sure there too tall for your ft truck, dooooonnnnnoootttt waste your money on the orions, iv swelled two of them so far
rickybobbyxxx is offline
Old 04-14-2012, 02:19 PM
  #21433
n8b
Originally Posted by rickybobbyxxx
ac
Thanks guys. That's the stuff I'm looking for. Almost pulled the trigger on the orion pacs.
Anyone running the Pro-match saddles with the RX8/4000?
n8b is offline
Old 04-14-2012, 02:25 PM
  #21434
Grouchman's Avatar
Trader Rating: 76 (100%+)
ac
I run the Orion 5500 90c saddles, which I run for racing and never had an issue. I've been running them over 4+ months. I also use some Protek 5100 50c saddles for practice. My old Genace got puffy but they lasted me 6 months.
Grouchman is offline
Old 04-14-2012, 03:48 PM
  #21435
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
AE boys are topping the qual boards at the Jconcepts winter nationals in Dallas , TX. Marcus is 10th right now after two rounds, running his Durango I think . Less the one second between 5-10th in qualifying times. Super close racing!
Cameron Kellogg is offline
