Like Tree5Likes
SC10 4x4 Thread
Old 03-27-2012, 10:55 AM
  #20146
bagged69chevy's Avatar
Trader Rating: 22 (100%+)
What are you guys using to clean your trucks to make them all shiny and pretty?
bagged69chevy is offline
Old 03-27-2012, 11:22 AM
  #20147
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Originally Posted by Farmer_John
Check the trans cases. If you over tighten them, the screws can extend into the cases and drag on the pulleys. All 6 screws should have washers. I tighten, then back the screws out 1/8th of a turn. Usually does it, YRMV.
Read your post again. Check the belt tensioners too, that they are tucked into their pockets and again does not come into contact with the pulley.
There's really only one way the front pulley can be installed. The Clicker assembly shouldn't have an effect on that.
It was a trans screw that was to long
kjohnsiii is offline
Old 03-27-2012, 11:28 AM
  #20148
Evil Genius jr.'s Avatar
Trader Rating: 28 (100%+)
Kal-gard prep and shine. Spray it down electronics and all and then go over it with a paint brush.
Evil Genius jr. is offline
Old 03-27-2012, 11:46 AM
  #20149
Farmer_John's Avatar
That stuff is the bomb. Just can't find it locally.
I use WD40 instead.
Farmer_John is offline
Old 03-27-2012, 11:49 AM
  #20150
Track just started carrying it
Old 03-27-2012, 12:16 PM
  #20151
R/C Tech Elite Member
jccj816's Avatar
Trader Rating: 38 (100%+)
Would a Reedy 4.5 550 be good motor to run? Indoor, high traction track
jccj816 is offline
Old 03-27-2012, 12:52 PM
  #20152
Rick Hohwart's Avatar
Either that or the 4.0 Reedy 550.
Rick Hohwart is offline
Old 03-27-2012, 12:55 PM
  #20153
Tech Legend
Wild Cherry's Avatar
The great Rick Hohwart , right on !
Wild Cherry is offline
Old 03-27-2012, 12:57 PM
  #20154
ktm11rider's Avatar
Trader Rating: 52 (100%+)
I stuck with the same gearing when i made that change. Running a 14t pinion now on large outdoor tracks.
ktm11rider is offline
Old 03-27-2012, 12:58 PM
  #20155
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
how big a track?
I found that with a 5.5 Tekin on a 50 x 50 track I am gearing 11T pinion 62T spur and it gets me reasonable temps (150s).
Cain is offline
Old 03-27-2012, 01:27 PM
  #20156
Krio's Avatar
Trader Rating: 159 (99%+)
Originally Posted by Cain
how big a track?
On a 100 x 50 I gear my 4000 pro4 15/62 and temp about 160 after 5 minutes.
Krio is offline
Old 03-27-2012, 01:34 PM
  #20157
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
Here's proof that AE reads this thread.
JEFFs SC10 is offline
Old 03-27-2012, 01:44 PM
  #20158
Tech Legend
Cain's Avatar
Yeah, Ricks a good guy. Would love to see more input from him on the thread, especially with anything on the way as far as further tuning options like stiffer rear springs, etc.
Heck, curious too about his thoughts on the RC Shox product like, especially the whole center diff setup.
Cain is offline
Old 03-27-2012, 02:07 PM
  #20159
Tech Legend
Use to use Wd -40
then discovered Lemon Pledge ...
But soon after switched to Endust cause it was. 003sec faster than all the others and made me ride look brand new ...
Old 03-27-2012, 02:20 PM
  #20160
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Wild Cherry
Use to use Wd -40
Cameron Kellogg is offline
