tire baking
#32
This is interesting...
anybody had a problem with the wifey complaining bout the smell? how do you get rid of it (the smell)?
I might try it on my sister's toaster oven
#33
Theres no smell if you boil them..
#35
Best thing is to find an old toaster oven where the toaster part no longer works. The oven part will usually outlast the toaster. Keep it in the garage or workshop and then use it outside so the wife won't complain about the smell.
Of all the methods described I found that the only reliable, cleanest and safest way to remove the tires is the baking method. The best part is that the rims, tires and foams are almost always reusable. (The foams will sometimes just be dead and dried out due to age and not from the baking.)
#36
i confiscated my parents toaster oven and put it in the garage. then i just went to walmart and bought a new one for like, 25 bucks. it was 25 bucks well spent too... i can reheat pizza, or make burgers while im wrenching so i dont have to go upstairs too
#37
What about debonder? Have you tried it?
#38
Neither debonder nor boiling has worked for me. The only thing that worked for me was baking.
#39
how long did you boil them? I boil my tires for 1 hour...
#41
My tank of propane would get used up anyway. You can reuse the inserts from boiling but you have to let them dry a while first. (Air dry for a few days or blow-dry for a few minutes). And boiling doesnt stink up the trailer or require cleaning anything. (I use an old pot for it, my mom would kill me if i used a good one!)
#42
#43
I use CA tire glue also. Oh and it's stronger because somehow they have rubber in it, so it flexes instead of breaking.
