transmitter batteries?
i was wondering if i should switch to rechargeable batteries (lipo packs) for my transmitter. most of them are 11.1V 2200 mAh batteries. regular AA batteries only last me a few days but how long should i expect the lipo batteries to last? im using the stock transmitter/radio that came with my team associated sc10 and it has a little thing at the back to plug in a charging jack.
Hobbyking sells a lipo that would fit that just fine. They're out of stock though .
That radio is pretty good for a starter. Just about the only thing I wish it had is the ability to do expo, which will make your steering smoother. As long as you periodically check the voltage and charge it before it goes too low, you'll be fine.
You can buy a LiPo and low voltage indicator thing from hobbyking.com. I have bought both and installed them in that AE Radio.
These are the parts you'll need:
3s 1450 mAh LiPo
3S battery monitor
Servo Wire exention
The servo wire extension is used to make a plug for the battery inside the radio.
If you decide to go this route PM me if you want some help or have any questions.
I also did this mode to a Traxxas radio and my Airtronics M8.
Craig
3s 1450 mAh LiPo
3S battery monitor
Servo Wire exention
Craig
Eneloop AA batteries.2,000 ah and low self discharge.
DON
DON
