Rookie with gearing question SC10 brushless spur gear. >
Old 04-22-2011, 05:59 PM
savannahmick's Avatar
Default Rookie with gearing question SC10 brushless spur gear.
I have a SC10 b.less with stock electronics and I am trying to get rid of a little torque/wheelspin out of slow corners. Anyway I bought a 84 tooth spur to replace the 87 tooth is this a to small of change to make a difference? Also will my motor run hot with this spur gear or is that only with a pinion change? Thanks for any input on getting a LITTLE less wheelspin and more top speed but like I said just a little! I'm running top five in club race but can't accel out of corners like I need to and I have tried many tires and susp. tweaks and hopups and 5000wt diff oil which did help some. Thanks Again!
savannahmick is offline
Old 04-22-2011, 06:22 PM
SCTom's Avatar
Dont change your gearing, that wont help your condition. Add some rear toe in to the rear end and a couple oz. of weight in the rear. More importantly try to be less agressive on the throttle.
Tom
SCTom is offline
Old 04-22-2011, 07:10 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
I don't fully agree Tom, the gearing change can help with some wheel spin to a point, how much you will notice depends on the driver. And only use it as a tuning add as long as you stay within the desired temp range.
OP how much help it will be, not sure, try it and find out. The 3 teeth on the spur will be about the same as adding a tooth to the pinion, not exact but close.
racer1812 is offline
Old 04-22-2011, 07:13 PM
correct on the spur gear. 3 teeth smaller on the rear is like one tooth larger on the pinion. 3.4 is the correct amount I believe. but 3 is close enough.
as long as motor temps dont go up to high you will be fine.
rear toe will help you track straighter if thats a problem. if its just wheel spin then add weight as noted. have you slid the battery back yet?
hammer down is offline
Old 04-23-2011, 01:15 AM
Anything wrong with just loosening the slipper? Trying to do it your way is like taking down the torque by shifting up. It's more stress on the motor / esc for sure.
Yet another option is to get a radio with a throttle curve / expo.
BoneDoc is offline
Old 04-23-2011, 02:49 AM
Default Yeah I know getting a transmitter with throtlle expo would be better.
A have already tried toe-in and other adjustments. Like I said there are only three or four trucks out of twenty that I can't catch or run with so my truck is set-up nice. I was looking for cheaper way to reduce wheelspin until I can buy new transmitter. Thanks Again! What is a good temp for the 3300kv Reedy?
Old 04-23-2011, 04:47 AM
Anything less than 200 F for an inrunnner is acceptable.
BoneDoc is offline
