How do I charge?!
Old 04-22-2011, 01:39 PM
SubarooMike's Avatar
Questions?? How do I charge?!
Hello! I just got a new charger and i'm wondering how do I know how many amps to charge my battery??? Thank you!
SubarooMike is offline
Old 04-22-2011, 01:40 PM
racer53's Avatar
What type of charger and what type of battery???
racer53 is offline
Old 04-22-2011, 01:50 PM
They batterys are all 3s but different Mah's. The charger is a Thunder AC6
Old 04-22-2011, 01:52 PM
racer53's Avatar
Well, ideally you want to charge at 1 "c"...heres an example if you have a 5000mah battery you want to charge at 5.0 amps...if you have a 3800mah pack you want to charge at 3.8 amps...ect...
racer53 is offline
Old 04-22-2011, 01:54 PM
racer53's Avatar
http://www.rchelicopterfun.com/rc-lipo-batteries.htmlHere's an excellant write-up on lipos...credit to finding this site goes to Duster_360
racer53 is offline
T. Herwig's Avatar
Trader Rating: 25 (100%+)
+1
T. Herwig is offline
Old 04-22-2011, 03:06 PM
Thank you for thre write up on lipos! I have it saved to read this evening. And thanks for the info on what amp to set it at. I am at the moment charging a 1600 Mah battery. I set it to 1.6 amps, and its been and hour and its still charging. Is that normal?? Seems king of long.
Old 04-22-2011, 03:08 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
normal, charging at 1C will take about an hour weather it's a 1600mah pack (1.6 amps) or a 9000mah pack ( 9 amps), 1C is 1C.
racer1812 is offline
Old 04-22-2011, 03:11 PM
poppa_duce's Avatar
Depending on how low they are drained my 3s 3300 and 2s 5300 both take right at an hour. I use the same charger.
poppa_duce is offline
Old 04-22-2011, 03:13 PM
racer53's Avatar
+1 you can also check how the batteries doing by looking at the voltage on the charger...if it's an 7.4v[2s] pack it will be done when it gets to 8.4v...if it's an 11.1[3s] pack it will be done when it gets to 12.6v...
racer53 is offline
Old 04-22-2011, 03:17 PM
Super Moderator
racer1812's Avatar
not 100% correct, close but not 100% charged most of the time. It will hold the pack at 8.4v and continue to charge untill it reaches 100% capacity, gradualy droping in charge amps...this is normal, don't freak when it continues to charge when it reaches 8.4v (if it's a 2s)
Old 04-22-2011, 03:44 PM
racer53's Avatar
I would think you know this Racer53
My bad...I worded that wrong...please disregard my post and read racer1812's instead...
Whoa...was there a little hostility in that last line...whats up with that
racer53 is offline
Old 04-22-2011, 03:47 PM
Super Moderator
racer1812's Avatar
No hostility, I was just assuming you knew that. Which you do. I guess I should have put it as a question. All good
Old 04-22-2011, 03:48 PM
racer53's Avatar
Ok, I probably read it wrong...
racer53 is offline
