Vented V2 Slipper Hub >
Old 04-21-2011, 05:18 PM
Ediaz's Avatar
Default Vented V2 Slipper Hub
Hello
Any one tried these? Kind of makes sense, remind me of vented brake rotors
http://www.teamassociated.com/news/l...V2_Slipper_Hub
thank you
Edgar
Ediaz is offline
Old 04-21-2011, 05:25 PM
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
They have a new slipper pad out too.
High Torque Slipper Pad
Cameron Kellogg is offline
Old 04-21-2011, 05:32 PM
racer53's Avatar
Nice...
racer53 is offline
Old 04-21-2011, 06:22 PM
Jmuck69's Avatar
Trader Rating: 14 (100%+)
I have the vented hub mounted now and will try it on Sat. The new pads will fit all AE offroad kits, but seems to be geared for the SC10 4x4. The extra torque of the 550 needs it.
Jmuck69 is offline
Old 04-22-2011, 02:56 PM
the vented plates do make quite a large improvment on slipper consistency
Andrew Swanson is offline
Old 04-22-2011, 05:00 PM
chris c's Avatar
Trader Rating: 60 (100%+)
you could use this to make your slipper vented also
chris c is offline
Old 04-22-2011, 05:04 PM
Jmuck69's Avatar
So will this!
Jmuck69 is offline
Old 04-22-2011, 05:41 PM
rctouringracer's Avatar
Originally Posted by Jmuck69 View Post
So will this!
Your sick! seriously should I use a a .45 or a 9mm?
rctouringracer is offline
Old 04-22-2011, 06:04 PM
how much airflow is it going to get inside that gear cover anyways
looks like a waste of money to me
artie's liver is offline
Old 04-22-2011, 06:09 PM
racer53's Avatar
It's not as much about air getting in, more about heat getting out.
racer53 is offline
Old 04-22-2011, 07:05 PM
OK, so where's the heat going in that enclosed air space inside that gear cover (right next to that big aluminum motor mount plate that's also a motor heat sink)
all that air inside that gear cover is going to be well above ambient temps, those holes are all show, just taking advantage of people who think vented rotors in full size cars are cool
Old 04-22-2011, 07:11 PM
rcdrtrcr's Avatar
Trader Rating: 25 (100%+)
not on a x factory..
rcdrtrcr is offline
Old 04-22-2011, 09:01 PM
I have drilled and slotted rotors on my car and they help A LOT!! So I don't see why this won't help.
Ty
x60Driver is offline
Old 04-22-2011, 09:10 PM
The holes aren't for heat, they cut down on glazied pads and make the slipper more consistant throughout the run.
busdriver is offline
Old 04-22-2011, 11:25 PM
And who actually runs a gear cover?
Dr_Isotope is offline
