havoc pro sc stutters >
Old 04-02-2011, 11:46 AM
Default havoc pro sc stutters
Hello,
I have the following
Losi scte 4x4
Spektrum DX3E radio with sr300 reciever
Savox sc-0252 steering servo
And Havoc Pro ballistic 550 4.5 system
Have been experiencing cut outs and stutters during acceleration. Has happened at all speeds even from starting from a stop. I have tested it off the ground so I can watch for any
change in lights on the esc but even when it cuts out all lights stay on and a second or to later the car takes off again. I did try a spektrum spm 1600 voltage protector. Did not correct problem.
Need help. Thank you
amosmix is offline
Old 04-02-2011, 11:58 AM
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Its either the sensor wire , or the sensor pack in the motor .
BashemSmashem is offline
Old 04-02-2011, 11:59 AM
Wolf1007's Avatar
Trader Rating: 33 (100%+)
I had the same problem with mine. Thought it might have been a battery connection but it definately was not. it happened the first day I used the system in SCRT-10. I immediately got rid of the truck for other reason and I still have the system. I am sure it will do it in the new SC10 4x4, and when it does I am sending it off to Novak.
Wolf1007 is offline
Old 04-02-2011, 12:11 PM
Just tested the motor hall sensor test and all seems good.
amosmix is offline
Old 04-02-2011, 12:13 PM
Default Stuttering
What kind of batts are you using ? They may not be strong enough. Also check your wiring for cold solders. If you set your esc for high take off it will stutter if the bats are not strong. 50c or better. I have a Castle that was doing that and found a motor connector wire had rubbed thru insulation to bare metal causing the truck to stutter and shut down then re-start.
TOYS ARE ME is offline
Old 04-02-2011, 12:23 PM
Wolf1007's Avatar
Interesting. I was using Pro-Tek lipos that are 5000/40C. Could that really have been it?
4x4 SC is pretty new to me so it may very well be my mistake.
Wolf1007 is offline
Old 04-02-2011, 12:28 PM
using a fantom 5400mah 25c lipo
amosmix is offline
Old 04-02-2011, 12:32 PM
I am using 5200 30c batteries and its smooth no stutter/cogging .
Could be something wrong with the ESC , mine would cut out and re arm sometimes and did so for a while before before it stopped working altogether .
Old 04-02-2011, 12:38 PM
seems like sometimes i go to put it in reverse and nothing then all of a sudden it takes off.
amosmix is offline
Old 04-02-2011, 12:39 PM
colter's Avatar
Trader Rating: 22 (100%+)
I would try a receiver cap, like the Novak Glitch Buster. Sounds like this could be the problem.
colter is offline
Old 04-02-2011, 12:42 PM
I tried the spm1600 spektrum voltage protector , is that the same?
amosmix is offline
Old 04-02-2011, 12:47 PM
SKIMAN's Avatar
Trader Rating: 17 (95%+)
I would try and sell the novak system and stay away forever...I have had novak's with issues and novak acts like they have never heard of such a thing..how ever check the novak forum....junk..just my 2 cents....and by the way I have 2 systems...wanna buy them?
SKIMAN is offline
Old 04-02-2011, 12:55 PM
I'm glad I just read this I was just considering buying one of these or the mmp for my sct.
Mike_Shepard is offline
Old 04-02-2011, 01:38 PM
If I keep the motor , what would you suggest for a good esc?
amosmix is offline
Old 04-02-2011, 01:44 PM
Tekin RX8
It runs just as smooth as the Novak and runs much cooler , so much that I dont even run with a fan on it .
