is loctite ok for a screw that screws into plastic >
Like Tree5Likes
Old 04-07-2011, 03:14 PM
sstumpf's Avatar
Trader Rating: 17 (100%+)
Default is loctite ok for a screw that screws into plastic
is it ok to use the blue loctite for a screw that goes into plastic. also of my screws keep coming loose on my stampede. just want to make sure it is ok for plastic.
sstumpf is offline
Old 04-07-2011, 03:17 PM
AWDPete's Avatar
Team Durango tells you to use Red loctite on there "plastic" but not sure about using blue. Might want to Google Loctite and check there website?
AWDPete is offline
Old 04-07-2011, 03:19 PM
LasagnaCat's Avatar
Trader Rating: 160 (100%+)
Elmer's glue
LasagnaCat is offline
Old 04-07-2011, 03:21 PM
PnchoPwr's Avatar
Trader Rating: 19 (100%+)
Blue loctite would probably be your best bet. Red is for a more permanent bond.
PnchoPwr is offline
Old 04-07-2011, 03:25 PM
sstumpf's Avatar
ok what about CA glue. i have seen were people say CA glue to plasic is what loctite is to metal.
sstumpf is offline
Old 04-07-2011, 03:57 PM
BigRM's Avatar
What you want is Tamiya Thread Locker. Loctite will eat into the plastic, making it brittle. I learned this the hard way. Used some on one of my buggies, when I picked it up in the morning, the whole chassis broke into 20 or more pieces.
BigRM is offline
Old 04-07-2011, 04:06 PM
100% NO"
Dave_S likes this.
Chuck 21 is offline
Old 04-07-2011, 04:08 PM
100% correct" CA glue also works for thread lock
on plastic.... Any loctite any color is death to plastic (period)
Chuck 21 is offline
Old 04-07-2011, 04:12 PM
DRUNKENMASTER's Avatar
DRUNKENMASTER is offline
Old 04-07-2011, 04:20 PM
Originally Posted by DRUNKENMASTER View Post
It's cheaper to buy a bottle that says CA glue on it then to buy CA glue
that says plastic thread locker on it... LOL"
Chuck 21 is offline
Old 04-07-2011, 04:50 PM
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
Use CA glue to plastic. It will bond but isnt made for long term but will do the job until part can be replaced or reglued.
NitroXray80809 is offline
Old 04-07-2011, 05:36 PM
BigRM's Avatar
CA is too brittle and will shatter when exposed to too much vibration. Anaerobic gel thread locker, like the Tamiya stuff, will flex slightly, dampening any vibration that would otherwise cause the screw to back out.
BigRM is offline
Old 04-07-2011, 05:40 PM
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
I should be sponsored by Blue Loctite I use so much!!!!!!!!!!!!!!!!!!
Have never had a problem nor have I ever heard of it damaging plastic!!!!
EVER
alvinsmith75 is offline
Old 04-07-2011, 05:42 PM
Funny thing is I just purchased some Loctite Super Glue at Lowe's. I have been told that super glue is ok to use. Anyone know if I am ok or do I need to return. Have stripped screw that attaches Rustler shock to RPM arm.
Murray100 is offline
Old 04-07-2011, 05:51 PM
Timbulb's Avatar
Loctite will eat into the plastic, making it brittle. I learned this the hard way. Used some on one of my minis, when I picked it up in the morning, the whole chassis broke into 20 or more pieces.
x2
Timbulb is offline
