SC10- Traction issues through turns
My setup -
Stock rtr shocks with stock fluid
Blue springs in front, green in back
Good tires for my track
1 degree hubs
Weight placement per ryan cavalari
4th hole drilled in rear shock tower
My problem is when I am cornering hard and trying to accel through, the inside rear tire is almost coming off the ground and I can hear the tire spinning, trying to grab traction.
Is there a simple solution to try and keep the rear planted through a corner?
1 degree hubs
Is the battery placement forard or all the way back?
Have you tried the sway bar it helped a little with mine on a indoor carpet track. I also run the red springs in the front and it helps with the body roll.
Ya I was going to say the ball diff might be a tiny bit to tight, also are you running expo on your throttle? This alone can make a night and day difference. Try it out, the change in trigger pull is annoying at first but after 5min you'll forget all about it because you driving will be alot better. Also I like to run 3deg's in the rear. Also like to run 1/4 rebound in the front/rear and 30deg caster blocks in front.
I could tell you your never going to get all the traction you desire on a 2wd truck. Driving these trucks fast requires a ton of finesse, to me that's what makes driving them such a blast especially when you out drive all your friends with the same truck or people you don't know! Lol see ya out front! Hope this helps!
I've noticed the problem with wheelies is it's really hard to steer with the front wheels off the ground..
