Bumpy low bite tires
Newb getting back in to the sport after a long break. I just built my new Losi 22 and am trying to decide what tires to put on it. From what I understand the track that I will be racing at is fairly bumpy and somewhat slick. It is an outdoor track, and I'm not sure what type of dirt it is. Just curious what tires I should look at getting. Thanks in advance for any advice.
http://www.rc-truckncar-tuning.com/r...road-tire.html
+1 JConcepts Doble D (green compound) or Proline Holeshot 2.0 M3
any soft compound pin tire should work well. Green double D's, m3 holeshots, or pink hot bodies gigabytes or megabytes. Proline closed cell would probably be better than the jconcept closed cell on a bumpy track since the proline is a bit softer. You may even want to stick with the stock foam.
Fronts are a matter of preference but a soft ribbed tire is probably a solid choice as a starting point.
