1/8 e truggys
Losi, Ofna, HPI, Caster, Durango (not released), Kyoshi, AE, XRay, and Hot Bodies all have a production electric 1/8th scale buggy, some even have truggies.
I have a feeling with time they will come.
I do think that the Truggy platform may have less appeal though as there is a stronger population that race buggy and truggy is still a small niche. At least around my area.
If your like me you get a Kyosho ST-RR and make a custom chassis for your BL conversion.
tekno v4, even v3 are the best way to convert to e-truggy. Mechanical brakes are a manditory part of a truggy conversion that will last. You can take losi's e conversion parts and make your own, ae had one maybe stillll does.. At any rate it comes down to the stress these bigger trucks put on the electronics. Your choices are much smaller with reliable equipment that can take the abuse. Another problem is driveline wear with the forces envolved. This is where the traktion drive or electri clutch come in handy.
don't be afraid just go tekno.
A good way to learn more about your RC is to do a conversion IMO. When I 1st started, adjusting the pinion/spur mesh or adjusting the toe on a RC seemed the most I was going to be comfortable with. I'm still not a RC "tech" but now I can rebuild diff's, shocks and put a dis-assembled RC back together fairly confidently.
The Xray I converted over myself and the Losi was already done but I had the whole thing apart to go thru it anyways.
RC Monster or Tekno, I dont think you could go wrong with either. They both seem to be quality kits. Its actually pretty simple once you do one....and then two....and then 3rd etc.
http://www.rc-monster.com/proddetail...Mslipperential
[QUOTE=Yosh70;8899695]RC monster makes what they call a "slipperential" which replaces the center diff. I purchased one for my Xray for that very reason.
[url]
great part no doubt.. But for it's cost you can get the full tekno v3 kit with traktion drive, for a few bucks more the v4 w/ traction. Not to mention teknos can be used as a e-clutch on looser tracks.
[url]
Team Associated RC8BE.. AWESOME BUGGY
TE RC8T Factory Team and use the TE E-Conversion which is the exact same e-parts the RC8BE uses.. SAME RESULT= AWESOME TRUGGY !!
Mechanical or Electric Motor Brakes is just a personal preference.. I have no problem with either, but prefer the Electric motor braking... lighter and less components to go bad..
You have a misconception of e-conversions.. 90% of e-buggies are just a production run of converted nitro buggies.. and they all work great, so why wouldn't a truggy be the same???
my 2c anyway.
[QUOTE=8ight-e;8899729]
True but do not forget rcm slip diff can go with u when you change car, tekno can't.
Both work the same but it's all abt preference
[url]
[url]
[QUOTE=SuperEk4;8899990]Good point.. ya if you swapped companies for truggies you would have to have a matching tekno kits to keep using the traktion/clutch drive. I saw one of the slipperentials last summer,, a real work of art too.. awesome unit.
Amen brotha, I hope it takes off this year! I just have a problem with ditching stock chassis and buying a new one and then buying mech. brakes. I might just get an Eco and know there will be an elec. Buggy class at the barn. barnstormersrc.com . Thanks for the replys
