Old 02-16-2005, 07:58 AM   #226
B3x
Looks like the RC18T FACTORY TEAM is coming in March:
http://www2.towerhobbies.com/cgi-bin...?&I=LXKAP3&P=7
for 189 bones !
B3x is offline   Reply With Quote
Old 02-16-2005, 08:35 AM   #227
warpig's Avatar
if it's all aluminum stuff.. no thanks
warpig is offline   Reply With Quote
Old 02-16-2005, 09:44 AM   #228
TPhalen's Avatar
R/C Tech Charter Subscriber
warpig: It won't come with all the aluminum stuff....just stuff like the threaded shocks, dogbones, heatsink motor mount, etc.
The arms, towers, etc will come in the Factory Billet kit....separate entity.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 02-16-2005, 09:46 AM   #229
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Any word on a chassis upgrade?
I got the Carbon Fiber one form HoleShot Engineering and it is super ridgid and realy helps the performace and helps to eliminate the torque steer.
Thanks,
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 02-16-2005, 11:55 AM   #230
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
Thanks,
Stephen <><
Got a link for that chassis? Thanks!
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6
ImGoinRCn is offline   Reply With Quote
Old 02-16-2005, 02:51 PM   #231
TPhalen's Avatar
Thanks,
Stephen <><
Torque steer???? Wow. I have a Mamba 8000 in mine and no torque steer. Hmmm...
Anyway, I have on of those chassis on another truck. Not to bad. Do you have the newest version with the new rear toe/motor mount plate???? That makes the BIGGEST difference in that chassis setup.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 02-17-2005, 12:35 AM   #232
beetlebz's Avatar
Send a message via AIM to beetlebz
as long as those threaded shocks are aluminum! my only complaint thus far is i go through shocks like water. if im not bending the shafts im breaking the bodies :O then again, i abuse her. and she loves it!
beetlebz is offline   Reply With Quote
Old 02-17-2005, 08:16 AM   #233
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Hope this helps.
Stephen <><
Old 02-17-2005, 08:26 AM   #234
Yes it is the newer version and yes that motor pod/plate is awsome. That was one of my complaints about the plastic chassis is that once you srewed in your motor mount you had to keep tightening it because of the kind of abuse I put my 18T through.
I have all the upgrades that are worth having and the 18T drives so nice now. One little help that seemed to really help the 18T in flight was to add about 25grams to the rear end to help keep the nose up especially if you get aluminum shock towers. Oh you can get some little wieghts from AE they are the little lead stick on type. Hope this helps,
Oh and the torque steer is probibly more my own with poor setup. Since converting everything I never thought to re-set everything to original settings i.e. camber, toe-in and ride height. So once I got the chassis I had to so now she runs nice and straight and has no real problem except the servo. If only you offered a metel geared one. I tried using a Hitec HS81mg wing servo but I have to use shoe goo to hold it in and if you do cart wheels you can unlodge the servo from its mount. I am still working on a mounting system for it.
Take Care All & GOD Bless,
Stephen <><
Old 02-17-2005, 10:21 AM   #235
Regional Moderator
ImGoinRCn's Avatar
Hope this helps.
Stephen <><
Yeah, that's it. Thanks bro!
X Factory R/C X-6
Old 02-20-2005, 10:06 AM   #236
RCMadness's Avatar
Default 1/18 Truck Nats Rules Update
2005 1/18 Truck Nationals Rules
Sponsored by Team Associated & R/C Car Action
ALL Races will be 5 Minutes Long.
4wd Stock Class (Stadium Style)
Sponsored By Team Associated
Must Run Stock Factory Chassis, NO Modifications to the Stock Chassis
Rubber Tires ONLY, NO Oversized Tires
Tires can not be cut down to be narrower
Handout #290 Reedy Mini-Max Modified Motor ONLY
Open Electronics
Minimum Weight TBD
5 or 6 Cells Pre-Built 2/3A Type Battery Packs ONLY. NO Matched Cells
After Market Shocks, Arms etc.. are acceptable
4wd Modified Class (Stadium Style)
Open Chassis
Open Brushed Motor, No Brushless Motors Allowed
Open 1/18 Sized Tires
Open Electronics
Battery Voltage not to exceed 8.4 Volts
4wd Brushless/Open Class (Stadium Style)
Sponsored By Castle Creations
Open Chassis
Open Motor
Open Electronics
Unlimited Battery Voltage
2wd Stock Class (Stadium Style)
Sponsored by Team Scream
Open Electronics
Minimum Weight TBD
5 or 6 Cells Pre-Built 2/3A Type Battery Packs ONLY. NO Matched Cells.
2wd Modified Class (Stadium Style)
Sponsored by MiniOffRoaders.com
Open Chassis
Open BRUSHED Motor, No Brushless Motors Allowed
Open Electronics
2wd Brushless/Open Class (Stadium Style)
Open Chassis
Open Motor
Open Electronics
4wd Mini Monster
DuraTrax
Open Monster Truck Chassis
NO Conversions
Open Motor
No Foam Tire, 1/18 Monster Truck Tires ONLY.
Tires can not be cut down to be narrower or smaller
Open Electronics
Battery Voltage Not To Exceed 8.4 Volts
Remember, this is a MONSTER TRUCK CLASS.
Novice Class
Sponsored by 3 Racing
14-Years-Old or Younger ONLY (Please Have A Birth Certificate Available)
Factory Rubber Tires ONLY
Stock Speed Control ONLY
Can Use After Market Steering Servo
Minimum Weight TBD
Fastest 1/18 Truck Exhibition
Sponsored by Castle Creations
Any and all 1/18 Trucks
The vehicle MUST be able to make 1 lap on the race track.
The truck, tires and wheels must conform to the 1/18 size.
NO Oversized tires & rims.
Unlimited motor
Unlimited battery voltage
NO NITRO/GAS ENGINES
1/10 Truck Open
Sponsored by SMC
Open Motor
8.4 Volt Maximum
Must Run FOAM Tires
NO Exposed Shock Towers
E-Maxx
No Spiked Tires
Open Motor
Open Battery
Remember, all packs for the stock & novice classes MUST be pre-built, from the factory, type packs. You can not buy single cells for the stock & novice classes, build them and use them.
RCMadness is offline   Reply With Quote
Old 02-21-2005, 12:21 AM   #237
beetlebz's Avatar
where will the nats be held?
Old 02-21-2005, 05:51 AM   #238
RCMadness's Avatar
The 1/18 Truck Nats are at R/C Madness in Enfield, CT.
860-741-6501 or www.rcmadness.com
Old 02-21-2005, 05:45 PM   #239
beetlebz's Avatar
wow, if only i had read your screen name... hehe
with a little luck we will be able to get our racing team bodies finished in time im reasonably sure the guys running the li-po's in the brushless class will walk all up and down my 18t, but i might go to watch. Ive never even been to madness, gots to go check the competition
Old 02-22-2005, 05:05 AM   #240
RCMadness's Avatar
I hope you can make it. If you use a 7 cell in the bL class the LiPo powered trucks won't walk all over you. Feel free to ask me any questions...
Dean
[email protected]
Upgraded Team Associated RC10GT non-pull start team truck AJ DRAGON R/C Items: For Sale/Trade 3 11-13-2006 10:57 PM
Brand new team associated rc18t 4wd mini monster truck jason cheng R/C Items: For Sale/Trade 3 03-11-2005 07:47 PM
Team Associated RC18T 4x4 Mini Truck Rowdy Racer Electric Off-Road 4 10-17-2004 11:38 AM
Team Losi mini T stadium truck mav Singapore R/C Racers 30 02-12-2004 04:25 AM
