Tenshock motors
Old 07-13-2011, 08:03 AM
  #61
Default Tenshock - Sc401 / 4000kv
I have 2 vehicles that i have set up with MMP and SC401 motors purchased through CK Hobbies. After reading alot of the comments on here. i figured I would try it on my backup truck. I must say, these are very strong motor. Ran a couple heats this past weekend in 100 degree weather on outside, dusty track. My vehicle settings were, Geared 14/46 in my Jammin-SCRT10. After heat 1, finished 3rd, temps at 148. Next heat, i went to my other vehicle running 12/42 on a Hyper10-SC. after heat, finished 2nd, temps again low at 146 after 6 minute heats. I had enough for on the low-end and top-end speeds. Enough punch to get me through tight corners into doubles and tons of top-end for the straight a way.
For the cost, i am pretty pleased with what I got out of them. Btw, primary vehicle is a sc10 4x4 with HW sc8 and CKhobby 4000KV motor. Geared 12t/60t. I know that is for another thread. But another awesome combo setup.
bcinntx is offline
Old 05-24-2012, 05:33 PM
  #62
TCCustoms's Avatar
Default esc?
ok, i will soon be ordering the sc411 4600kvfor my Losi scte and looking at running the sct pro from hobbywing...Alot of guys love this combo so that is why i chose it!
Would i gain anything from goin to the 150a xerun or ezrun and if so which would be better...I think im more excited just to get the motor than i am to run it, lol? Any help would be great as im almost ready to order!
Also, can you get spare parts like bearings or anything from these motors as i had a BL traxxas product and did use a set of bearings after 2 years of running so if i can get parts, where do i get them? Thanks
TCCustoms is offline
Old 03-20-2014, 08:58 PM
  #63
bigjerry's Avatar
Trader Rating: 53 (98%+)
whos the expert on theses motors sc401 4400 how do I wire it up
bigjerry is offline
Old 03-20-2014, 09:14 PM
  #64
Wiring is no different to any other sensorless motor
Connect all three wires, if it spins in the wrong direction swap any two to reverse it
What car are you putting it in ?
crusey_aus is offline
Old 03-20-2014, 10:17 PM
  #65
bigjerry's Avatar
Tekno SCT411
bigjerry is offline
Old 03-20-2014, 10:23 PM
  #66
Assuming you are running 2s lipos, gear the car for 35 mph and monitor your motor temps
What ESC are you planning to use ?
Cheers
Old 08-23-2015, 10:08 AM
  #67
anyone running 2100 or maybe 1900kv 6 pole motor on hobbywing SC 120A ESC? I have the 130A team orion version and reading about RPM limits for 6 pole motors, I feel like it may not work.
eMDee is offline
Old 08-26-2015, 11:12 PM
  #68
so I contacted hobbywing and got an answer ,that yes, 3000kv limit on 4s means 2000kv limit on 4s for a 6 pole motor + they suggest sticking to a regular 4 pole
eMDee is offline
Old 08-27-2015, 08:41 AM
  #69
and tech support from team orion says (conntacted also them, since I have orion/hobbywing speedo) :
"The real limit is Watt/Amp, the KV is just an indication.
6 pole is sort of new and probably will need specific firmware to work perfectly. But yes, it should work."
eMDee is offline
Old 11-21-2015, 12:20 PM
  #70
Default i want to know if...
Well i have a mamba max pro esc and i want to know if i can run tenshock 2400kv 6 pole with this esc? I'll run 3s and 4s...
Abrahamll is offline
