OFNA Nexx 10sc Thread
#782
The Xerun Pro SCT and 4000KV combo seems great may even be too much for my local track,
Lewis you mentioned zero timing and punch 6, the default timing is 15 so will it affect performance or just keep the motor cooler?
#783
As long as the motor is "too much", you should set timing to 0, and you can turn down the punch for traction control. The motor will run cooler, and batteries will last longer. Control in the corners is much more preferable than hurtling down the back stretch straight into the wall.
#785
Just won the summer long points series with a viper copperhead powered Nexx sc 10
#786
Well done Mugenlife, still coming to terms with mine but happy and enjoying the prep work.
#787
[QUOTE=mugenlife;11186252]Just won the summer long points series with a viper copperhead powered Nexx sc 10[/QUOTE gratz on the win
#788
Guest
Just ordered the lightweight chassis 80% roller from nitrohouse, should have it any day now. hopefully have it up and running pretty soon kinda curious how it handles compared to my hyper
#789
#790
whats the weight of a nexx without electronics , and how much does the chassis acually take off , i have a scrt10 so same chassis figured my advantage over losi is being light why not be lighter , i have everything mounted on the chassis and i run shorty packs side to side left 200g battery 70g esc,, right 64g servo 200g motor reciever mounted under front driveshaft and ive drilled 1/4 holes about half way throught in certain spots on the chassis and poliched it with a dremel since it looked horrible
#791
new to 4x4 sc
Hello just bought a ofna nexx10sc.
I have put a 2200 kv hobbywing motor with a mamba monster esc.
The truck is standard is there any up grades or modification that i need to do with it for racing .It will be ran on both clay and cement track.What are the better tyres for dry clay dusty surfaces. Thanks any help would be appreciated Ian
#792
For tyres calibers are good all round, I-beams are good and so are grid irons on clay.
Check the jammin scrt forum it is more active and basically the same truck.
#793
Guest
I've been running the light weight chassis Nexx 10sc on an indoor track the past 3 weeks now. Switching from an Ofna hyper 10sc I had been running. So far I am very impressed with the way the Nexx handles! Still getting the setup down obviously its only been 3 weeks but right off the bat first night I could not believe how much smoother and more forgiving this chassis is over the hyper! I'm running a castle mamba max race pro sc with a castle 3800kv 1410. Tons of power and always runs cool. Very happy with this truck so far and definately glad I stayed with Ofna!
#795
[QUOTE=yong7801;11313021]Depends on the track if it is flat (not 1/8 scale or blown out 1/10) the nexx as it is lighter and dont have to throw it around the course to put down faster times and it turns better. Big bumpy tracks the losi is better.
