OFNA Nexx 10sc Thread
#421
Loosen the 10 mm fitting holding the top pillow ball in place and either tighten the pillow ball for more - camber or loosen it for more positive camber then retighten the 10 mm fitting to take the play out but dont over tighten or you will make it bind. If you can get the pillow ball hole to line up through the 10 mm fitting you can tighten or loosen it that way as well.
#422
#423
#424
Just got my Nexx 10sc up and running, and it seems to be pretty noisy (ie centre diff gear noise) is this normal? ive played around with gear mesh etc and thats all good no binding etc, this is my 1st 4x4 sct truck had 2wd before and its alot noiser...
Im using the stock pinion that came with the truck, running a 4-pole cc1410 ive removed the motor and its ok..
Found these movies of someone elses SCRT10 and mines pretty well the same
This vid is with the car off... just pushing it back and forth with the motor meshed up to the spur:
http://www.youtube.com/watch?v=cQb4kCXXWq4
And this is without motor meshed up against the spur
http://www.youtube.com/watch?v=kwNjT-InTm0
As you can see, the car rolls like butter without the motor installed. No matter how tight/loose against the spur I set the pinion/motor, I get that grinding/binding.
Maybe its got something to do with the 4-pole motor..
#425
#426
Yeah i thought so, i ran a few packs threw it this arvo and all good..
Bloody great truck too i reakon, im very happy with my purchase..
Got another question? Just wondering what brand pinion gears people are using for a 3mm shaft?
Im running the stock pinion now with the supplied adapter, but id prefer not to use an adapter can i get Mod1 pinion with a 3mm bore that is as wide as the spur gear all the ones ive seen have a thinner gear..
#427
Does anyone have a good starting setup for loose outdoor track?
#428
#429
Hi,
Is there a inner body available for the nexx sc10 to protect from sand and stuff?
#430
I have 2 of these bad boys now so I took 1 out yesterday and was doing some super bashing and some really big jumps I mean really big 30ft plus !!On pretty much the bone stock rig just better shock oil and diff lube !! I gotta tell ya not one thing is broke or bent so for me when peeps tell ya that this truck is cheap and fragile (crap on them )!!!! LOTS OF FUN !!!
If you are on the fence jump over and get 1 or 2 like me !!!
#432
If anyone wants a gently used nexx 10 i got mine up on the bay! http://cgi.ebay.com/OFNA-NEXX-10SC-4...d#ht_700wt_922
#433
Anyone know of any shockboots that will fit the shocks on this truck?
#434
#435
Haven't seen much mention of adjusting the front roll center. Has anyone played with this ? I have a bit of an off power push and plan on playing with it a bit. Just curious.
