OFNA Nexx 10sc Thread >
Old 05-31-2011, 12:50 PM
  #406
el Bourlando's Avatar
Ive not popped a ball cup yet, they seem solid so far. I have pulled the swaybar arm mount apart. I just used ca glue on each threaded rod end and put back together, no problems since!
el Bourlando is offline
Old 05-31-2011, 01:56 PM
  #407
Did you race at the memorial day race in Indy?
mugenlife is offline
Old 05-31-2011, 04:49 PM
  #408
Yes, it was fun. I was able to take the TQ spot. I came up a little short in the main finishing 2nd. The track grooved up and the truck got a little tight in the corners, I probably needed a harder compound or diff tire or maybe even jus a wheelbase change. Of course the barrel roll onto my roof after the first corner, set me back in the field a bit. The truck was still good enough to win, I just wrecked and got too far behind too early. But it was a fun day of racing. We had over 120 entries with close to 30 in the 4x4sc class. Not too bad for a Memorial weekend in Indianapolis.
Old 05-31-2011, 05:25 PM
  #409
Old 05-31-2011, 07:10 PM
  #410
Was there any Losi or Associated 4x4 sc's? Just asking because some here try to say the Nexx cant keep up and where I race I clearly can even against drivers who I consider better than myself......Nice job btw
Old 05-31-2011, 08:37 PM
  #411
It was a losi that won and an ae finished in third. I pretty much gave it away on the start. They start double file nascar style and there is almost no advantage for tq. I made it thru the corner fine and singled over, then doubled into the carousel and cut the wheel too hard and rolled it over, I was trying to double out, in which case it would have been lights out! I came out in 4th but then I got dumped on the triple and it was a battle to make it back thru, maybe in a 10 minute main I could have got back to the lead after my mistakes.
In the video that corner had good moisture from rain, so I think that may have aided the roll overs in the carousel. Then on Monday by main time the track had a good groove and I think the compound I ran made it grab and rollover.
here is a video of the main from saturday before the memorial race, I am the yellow body with a blue stripe, I was running my practice body. You can see on the start I almost did the same thing.....doh
http://www.youtube.com/watch?v=_vt0y...e_gdata_player
Old 05-31-2011, 09:00 PM
  #412
I found the Memorial Day A main. You can see the conditions had changed from saturday.
http://www.youtube.com/watch?v=ot5Vz...e_gdata_player
Old 05-31-2011, 09:28 PM
  #413
Sweet I am about 2 hours north east of Indy and run at stateline and some at summit.
Old 06-01-2011, 05:15 AM
  #414
Default outerwear
hi has anyone tried if the outerwear for the Jammin SCRT10 fits the Nexx 10sc? wanna do sme protection for the truck...
thanx
chiatw73 is offline
Old 06-01-2011, 05:22 AM
  #415
Cool. Stateline is an awesome facility!! Kevin, Joe & Cory are
a great group of guys. I didn't make it up last year but have been there several times in the past. Fun place to race. I'm hoping to make it for the Kings race. I think a bunch of us are going to PPR on Sunday in Muncie.
Old 06-01-2011, 08:09 AM
  #416
hi guys.. how do i adjust the front chamber? is it the from the PBS hex screw on the wheel side?
thanx
chiatw73 is offline
Old 06-01-2011, 10:01 AM
  #417
thanx
Loosen the 10 mm fitting holding the top pillow ball in place and either tighten the pillow ball for more - camber or loosen it for more positive camber then retighten the 10 mm fitting to take the play out but dont over tighten or you will make it bind. If you can get the pillow ball hole to line up through the 10 mm fitting you can tighten or loosen it that way as well.
Old 06-01-2011, 10:06 AM
  #418
Sweet I just race electric now, we have a few big races and series coming up for that. Joe and Cory are running 22's now in electric and Cory is wnting a 4x4 sc. I ran mine box stock at summit and had the radio settings all wrong nd the rear springs needed to be blue not white.
Old 06-01-2011, 03:21 PM
  #419
-R2-'s Avatar
Good job Brian you're my hero right now.
-R2- is offline
Old 06-01-2011, 03:43 PM
  #420
HYPERBOY's Avatar
Can't wait to see all the Vegas guys tomorrow, I am heading out with one of my sponsors Novak to run their 2nd to last series race on Friday.
HYPERBOY is offline
