OFNA Nexx 10sc Thread
#271
Cant really go wrong with either I just prefer the Nexx over my old Hyper.
#272
I've been very happy and successful with my Hyper but also have the Jammin. Since I race on larger outdoor 1/8 tracks, the Hyper tends to deal with rougher conditions and handle the abuse better than the Jammin (which I use primarily on smaller, indoor clay trafcks where more finesse is needed). I'm waiting on my Nexx to arrive but am hopeful that it will be a nice middle ground between the Hyper and Jammin.
#273
I am having the same dilemma. I have had the Hyper and loved it. Its time to build a new 4x4 for the outdoor season. I am considering the Nexx10. I was curious as to why the weight increase from the hyper and jammin's 3.7 lbs. as a roller to the Nexx's 4.25 lb. as a roller? Is it just beefier? How are people doing with this truck on large outdoor tracks? I pretty much have my mind made up on the Nexx.
#274
#276
This truck is DURABLE.
I beat the crap out of this truck on 3s, on a Huge 1/5th scale Baja Track. Man Ofna really did step up and Make things Durable. The PBS held up pretty good. Waay beefier than the Hyper10sc. Only thing I broke was the rear wheel Hub, Quick easy STRC Swap and I was back on the track.
If your going to get the truck, Just replace the Rear Hubs with Alloy ones and your good.
I also Noticed I was a bit rear heavy. I moved my battery back prior before running it. If you run 1/8th electronics and a 550, I recommend you keep the batter tray mounted forward.
+1 OFNA
+1 OFNA
#277
#279
I ran my nexx 10sc this saturday at revolution raceway in appleton wisconson and I have to say the truck rocks!!! I finished everything at my hotel including painting the body and this was my first time on a track since last summer!! It took a couple laps but I got it down pretty quick!! I was running the turnigy trackstar 2560kv motor with the turnigy 150amp esc and for a cheap system it works pretty nice!!! I just had to make some minor adjustments with the program card and it was ready to rip!!! I didnt even have time to put fluid in the diffs or change shock oil!! So I was basicly running it stock besides the soft barcodes I bought from revolution. But Ill be going back at the end of the month and Ill be ready to race this time!!
#281
Hello guys, I'm running on a bumpy 1/8 track with some big jumps. Do you think I should go BB or four rear shocks will be just fine?
#282
Some say it runs smoother sensored, but i cant tell the difference. I have had no issues, no Shuttering, nothing with this setup.
I have the 4000kv 5.5 Tekin motor. I think you can run up to 3s with it no problem. I ran a 2s on it for a race and it was a rocket. 3s is just insane. I had it geared at 18t on 2s and 16t on 3s.
Overall I couldnt tell the difference between the 4.5 and the 5.5 motors. If you want to run 3s and 2s. go with the Tekin sc4x 5.5 The 4.5 sc4x is just 2s only.
#284
Thanks, I'll try the stock one first it it works.
