quick soldering castle esc question
ive never removed more, but i always add more tinning to the existing wire.
ive never had an issue.
Personally I always cut off what they tinned and i use my own solder...just my 2 cents
racer53 Personally I always cut off what they tinned and i use my own solder...just my 2 cents.
+1
+1
I wouldn't add to it because castle uses silver solder, I don't like to mix solder, I'd cut it off and start over
/\ this... also don't cut off too much insulation.. 1/8" is all you need.. remember to put heat shrink tubing on before you solder the wires up.. use a real hot soldering iron as well when soldering deans.. be fast.. i also plug the male end into a female connector to help dissipate heat to keep the plug from melting
60 watt iron is ok huh?
