New 1/10 Truggy....thoughts?
#32
#35
Thats a good question. I actually never thought of running it WITHOUT a center diff....I am so used to 1/8th scale buggies and Slash 4x4's with center diffs. The truck might work well with a solid center, since the wheelbase is so short(relative to a slash 4x4). Im gonna run it again on tuesday. ill ry it with and without and see...
#36
I dont typically bash, but I can say that it is tougher than the stock stampede 4x4, which Ive seen take ALOT of abuse. If you are bashing, there are so many tires to choose from for this truck, and bodies, too....look at all of the tires that just came out from pro-line for the 2.8 wheels....all of those will fit, too
#37
I really like the cars who could do different things.
Your "tuning" looks very good, that gives the opportunity to drive either a staidum truck or a monster truck with the same car, same electronic, same motor, I like the idea a lot.
#39
#40
Just for reference's sake the vid I posted with the Pede beating a whole field of race truggies was with no center diff. Depends upon the track though, and you have to work the sway bars as appropriate to make sure it rotates. On a loose surface I'm sure a center diff would be a huge help.
#43
Thanks for the info Jang. With how you set up your stampede, would you choose a stampede over a slash?
#44
do the slash and stampede 4x4 use the same a-arms?
