losi xxt caught on fire today.
my losi xxt caught on fire under normal driving conditions. the setup was tekin sport esc and a speed gems 15t motor, it is brushed. i was running a 6 cell nimh battery. it started to smoke then caught on fire. where the fire was, was the battery lead on the esc side. ther is still enough wire to solder on a new connector and see if the esc works. what do you think caused this. also do you think it fried the esc. let me know.
I had a Novak Cyclone go up in flames back in the day in a similar situation (though in a Losi XXX-S G+). I just replaced the damaged wire and it worked fine afterward (still sitting in my XXX-T MF2). As previously said, if the heat didn't get to the ESC and it was just a freak ground or +/- contact, it might still work.
ya im not sure that i want to plug my lipo in there. so what should i do. any way to test it. it caught fire on the battery lead on the esc side, not the battery side so does that tell you anything, could it be the esc. yes it was a tamiya connector and i have a deans i can solder on there and plug in my lipo to it.
