Traxxas Slash question.
#16
6900 is a bad choice especially if it's a two pole cm-36. The 1406 four pole 4600 is plenty on 15-16/54 with a two cell. Castle motors have always run cooler for me than any motor I've used in the last 18 years. It's all about setup. Timing will also generate more heat. Your esc settings will greatly effect the temps on your motors. I would read my write up on the 1406 at the above mentioned forum. There is a ton of info on it.
#17
Thanks for your input. I just figured I have that motor laying around already but that came out of a tc3. I also have a Velineon vxl-3 in a tc4 with the motor as well as a fuse system in another tc4 and a ballastic 17.5 turn in a Kyosho tf5. But their all cars so I guess thats the difference of why I cannot use them.
More research is needed on my end I see. I will learn!
#18
Ok, ill read up on your review a little later on, have some family things to do
#19
The differance is the 1406 is four poles and has twice the torque as opposed to the cm-36 and other motors you listed are two pole. Think of it as two pole equals high rpm very fast with nominal torque. Better for lighter cars. Four pole has same rpm but doesn't build quite as fast but has lots of torque. Better for heavier cars like 4x4 sc or 1/8 scale.
#20
Thanks guys above this post. I appreciate the info and explanations.
Just got home and need to shower than Ill sit down and read the review.
The deal with the 4600kv motor fell threw, so Im back to the drawing board. I have a MMPro esc so I just need a motor and want to stick with a Castle. Is their a better motor than the 4600kv that will work in this 4x4 or just stick with that? I'm going to be buying brand new now I guess unless someone that reads this has one they would like to sell. Paypal ready!! lol
Again, thanks guys for all your help so far. This place has alot of good info.
#22
Everywhere I have read about this 4600kv motor in a Slash 4x4, they DON'T recommend it. Supposedly, it is even said on Castle's website. Good thing that deal fell through. ( http://www.castlecreations.com/suppo...-advisory.html )
What I do recommend is, keep the Mamba Max pro ESC, and run a 4x4 short course edition motor such as the Novak setup. ( http://www.teamnovak.com/products/br...550/index.html )
#23
