Turnigy 5.0 5000 hardcase not fitting SC10!???? >
Old 03-10-2011, 06:34 PM
hayabusafmw's Avatar
Default Turnigy 5.0 5000 hardcase not fitting SC10!????
i just bought my sc10 brand new brushless rtr....
I then tried to fit a 5.0 5000 hardcase turnigy battery.... it doesn't even fit ''in height , and second problem the wires are in front of the battery
i personally never had a car that didn't have a large enough tray but anyways
let me know if the battery strap is adjustable or im missing something???
it can't be possible as 3s are way more thicker
hayabusafmw is offline
Old 03-10-2011, 06:54 PM
BigRM's Avatar
Start by replacing the screws at the rear of the battery holdown with ones that are about 1/4"-1/2" longer. Put a notch in the foam spacer and run the wires out towards the rear of the truck.
BigRM is offline
Old 03-10-2011, 07:15 PM
PhotoGreg's Avatar
Trader Rating: 19 (100%+)
I use the STRC battery hold down, and loosen up the thumb screws a few turns. Works well.
Greg
PhotoGreg is offline
Old 03-10-2011, 07:26 PM
jhess's Avatar
Default battery hold down.
The kit specs say to loosen the rear hold down bolts. If you do that you should be ok. I dremel out the round parts in the back to allow movement of the batts. I have run the 5200s and they give me about a half hour of run time with a moderately geared 3800.
jhess is offline
Old 03-10-2011, 07:39 PM
GizmoJunkie's Avatar
I know its extra money, but i would suggest the FT battery hold down.
You can get it to sit about any height you want, and have all the fwd/aft adjustment you want for playing with weight distribution.
GizmoJunkie is offline
Old 03-11-2011, 11:06 PM
bdyche's Avatar
You can loosen the screws on the front and rear to raise the height for the lid. Cut a small notch in the battery foam for the wires to lay in, and then you will be set. I'm running the same truck with the same battery without any issues.
bdyche is offline
Old 03-12-2011, 10:05 AM
jurquhart's Avatar
Trader Rating: 22 (100%+)
what's the name of the kit so I can order it. I have some turnigy's that don't fit
jurquhart is offline
