Switch Question for the GT. >
Old 08-29-2004, 09:19 AM
yodace's Avatar
Default Switch Question for the GT.
What is a good on/off switch to get for a GT?
Because the one I half doesn't appear to be long enough. I just installed the RPM receiver box and the wire leading away from the switch just barely reachs the receiver box.
Any part number or info on how to fix this problem would be helpful....
yodace is offline
Old 08-29-2004, 01:18 PM
Trader Rating: 28 (100%+)
You have two choices...
You can purchase an extension, but you now have one extra power connection.
The other option, which is much better is to purchase an extension that is long enough to reach all the way from the switch to the receiver. Cut off the male end of the extension leaving only the end that plugs into the receiver. Strip back the wires on the end that you have removed the plug. Pop open the switch and remove the wire that is too short. Solder on your longer wire that reaches the receiver. Snap the switch back together. Now you have a switch with a battery wire that is only one piece and it reaches the receiver. If you can solder, this will only take a few minutes.. Best bet would be for you to make a second one, as switches do fail and you will want to have a backup that is quick and easy to install while at the track.
Scott Fisher is offline
Old 08-29-2004, 04:18 PM
corradopsi's Avatar
or you could just buy a new switch with a handy dandy charging lead built into it like i run. then you never need to pull your pack to charge it, just take the car home and plug it in. all my cars packs last me an entire day of racing except my 1/8 buggy. but with the receiver box, its so easy to change it doesnt matter.
corradopsi is offline
Old 08-29-2004, 04:28 PM
yodace's Avatar
U guys have any part numbers?
yodace is offline
Old 08-29-2004, 04:57 PM
corrado:
According to the original question, the wire that plugs into the receiver isn't long enough. Having a charge cord on the switch doesn't make the power wire longer.
Yodace: If you go to your local hobby shop, they should have extensions. They are very commonly used in planes for the wing servo.
Old 08-29-2004, 09:44 PM
beetlebz's Avatar
i got a switch with my futaba radio, and i have a rear shock tower with a mounting hole for the switch (actually someone told me it was a mounting hole for a charging jack for nicds but it fits perfectly) and on my GT i have no problems reaching the reciever with the wire.
unless of course you mean a monster Gt, in which case ill shut my cake hole
beetlebz is offline
Old 08-29-2004, 09:55 PM
corradopsi's Avatar
Originally posted by Scott Fisher
corrado:
as some would think. however all the switches i have bought like i described, have much longer cords than your average switch. which is why i recommended it. it solves his problem and is an upgrade.
Old 08-30-2004, 01:23 AM
every switch that I have put on my GT has a charge plug on it and none of them have the power cord long enough to reach into the RPM receiver box.
