tried to bake my tires off, no good!
When I baked my old t4 tires off I used foil under the tires? I left them in about 10-12 minutes and once they cooled, they were just as easy coming off the rims as putting new tires back on the wheels. Even the left over glue on the wheels just peeled off in one sheet with no effort at all.
The only thing, maybe the foil will let the tires/glue absorb more heat to loosen the hold. The towel might actually protect the tires/glue from taking in the heat???
don't put towels in the oven
I had similar results with the oven.
I read about using a heat gun somewhere here on RC Tech and I tried it and works much better.
Keep the gun moving around the bead for 3-5 minutes and then simply pull the tire away from the rim. You will need gloves or a towel and some times it takes a good pull.
If it's stubborn, heat it some more and try it again. Repeat if necessary, it will work!
Anyone know if the baking or heat gun methods change the tire compound? It seems the heat would basically vulcanize the rubber and turn it hard also.
