Lipo
What does the c indicate? Such as 20c 40c etc.... Also I got a 2 cell 1000mah, will any 2 cell 1000mah work?
Originally Posted by cr8ter
(Post 8720975)
As to your second question, I'm not entirely sure what you are referring to. You have a 2s 1000mah lipo pack? |
(Post 8720975)
Example: 5000mah 2s lipo- 1c=5amps. 5amps X 20c=100amps
So a 1000mah 2s lipo 1c=1amp 20c X 1amp=20amps The c rating is based on the mah of the battery. Mah divided by one. Hope this helps, I just buy the highest rated packs I can afford, the higher c generally = higher performance all around. Google it for a very detailed explanation. |
Got it thanks. I just wanted to make sure it didnt mean its a bigger battery.
(Post 8721273)
not always though.you can buy a low c rate on a big battery. (not that you would want to) you can get 5000mah batteries anywhere from 20c and up
yea. I just realized the 1000 mah 20c I was going to pick up is bigger and won't work so I'm just going to get the 800 mah 20c
