losi 8ight t brushless help >
Old 02-25-2011, 04:12 AM
Trader Rating: 65 (100%+)
Default losi 8ight t brushless help
hey guys i have a losi 8ight t 1.0 with a mamba 2200kv setup runninf 4s tekno conversion.
i have a bad sounding clicking/cruching sounds when i brake really hard it is using the motor to brake the mechanical brakes have been removed.
i can accelarate as quick as i want and can brake fairly hard but if i just do sharp jabs on the brakes it makes the noise. i have checked front and back diffs but dont really know what i am looking for.
any input would be really good thanks
gnatsum69 is offline
Old 02-25-2011, 05:17 AM
symmetricon's Avatar
Trader Rating: 27 (100%+)
So you have no clicking on power, and only on brake when you jab the brakes. Does it continuously click when you hold down the brakes while slowing down? I would get it up to speed (on the street) and partially apply the breaks, not a complete lockup, and if you hear click click click, it sounds like you ring/pinion in the diff.
symmetricon is offline
Old 02-25-2011, 02:17 PM
neobart's Avatar
Rear diff most likely, if you're lucky it can be saved. Mesh needs to be tight.
neobart is offline
Old 02-25-2011, 02:29 PM
B.A. Racer's Avatar
+1 on the rear diff
B.A. Racer is offline
Old 02-25-2011, 07:41 PM
i thought if it was the rear diff would be more likely to make the noise under full throttle not braking?
Old 02-25-2011, 07:43 PM
thats correct no clicking under power only when i jab on the brakes. if i get the car upto full speed on the road i can still stop quite quickly without getting the noise but if i just jam then on it clicks but only a couple of times
Old 02-25-2011, 09:30 PM
neobart's Avatar
My truck did the same thing once, I could only hear the clicking when braking hard. Opened up the rear diff and ring and pinion where chewed up beyond saving. That's what I get for not checking the mesh often.
neobart is offline
Old 02-26-2011, 05:31 AM
8ight-e's Avatar
Trader Rating: 58 (100%+)
#1 buy the 8ight 2.0 rear diff housing
#2 shim it up better before it's too late, if it's not already too late.
I didn't post until now because it looked like everyone gave the correct answer, but hop on ebay snag a full rear 2.0 diff if you're smart and keep a few shims around for adjustment.
The 2.0 housing has less issues, but you need to shim and re-shim either the 1.0 or 2.0 versions to keep them healthy.
Good luck
PS this is pretty much only w/ the truggy and the rear diff. In 3+ years of racing the 8ight-e 1.0 and 1.5 buggy I've never had a single issue with either diff, while on my truggy I've replaced about 5 diff pinion/spur combos. This is with a neu 1700 on 5s, then a 2200 on 4s for the last year or so. My nitro has only had 1 go bad, so really it's the combination of brushless torque, and the weight of the truggy. I did swap over to a tekno e-clutch on my truggy and have not had one go bad yet, but I am also more careful w/ the shims now.
8ight-e is offline
