stampede wide front conversion
what is the easiest way to make the front of my stampede wider so it is even with the back. i like the nitro rush one with nitro rush arms in front and e maxx turnbuckles. then use my turnbuckles for camber links so if i did that one would the front be the same as the back and what all would i need to get for that. are there any other ones that are better and what is a list of things i would need
check out www.ulitimaterc.com
there is where the wide mod was born, and you'll find detailed instructions and part numbers, etc...
The easiest way is to do the protrac conversion on the front.
