tenshock sc401  short course Brushless MOTOR >
Old 05-07-2012, 06:54 PM
  #1336
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Feint Motion View Post
Its more than likely your ESC. Make sure there is no binding, in your chassis. Also check the motor bearings. Turn Timing off. They had a few issues with those.
I had the same issue running a MMM with a tenshock, switched to a Hobbywing sc8 esc, heat issues went away.
I thought it was the esc. Went on castle's website and flashing yellow meant possible problem with controller. My dad's friend runs the hobbywing c-xerun esc in his 8th scale buggy (150 amp) and his sc10 4x4 (80 amp) and has no problems whatsoever. Looks like a good buy for
$100. Going to order one tonight with the optional programmer.
I am also going to try running a 12 tooth pinion instead of the existing 15 tooth i have on there. Sucks i drove 4 hours just to watch my friends race instead of me, and Get a really bad sunburn turnmarshalling LOL!
Thanks for the help!
Rockthecatbox21 is offline
Old 05-07-2012, 09:44 PM
  #1337
RC*PHREAK's Avatar
Trader Rating: 140 (100%+)
If its a small technical track, you shouldn't need more than a 13T with the 5200. Maybe a 14T if you really feel you need it.
As far as temps, keeping it below 180 is advisable. I personally don't like going over 170.
Also as far as the hobbywing's go, if you don't plan on ever running sensored motors, go with the SC8. If you think you might run sensored, I'd go for the SCT-PRO esc.
RC*PHREAK is offline
Old 05-29-2012, 06:52 PM
  #1338
xxfile's Avatar
Mine ate the frt motor bearing about 6 packs in... i assume it to be a shitty bearing as no one else here has complained.
xxfile is offline
Old 05-29-2012, 07:50 PM
  #1339
Black or blue on the sct pro? What's the difference?
Old 05-29-2012, 08:41 PM
  #1340
RC*PHREAK's Avatar
only difference is color. no functional difference.
Old 06-02-2012, 01:43 PM
  #1341
Wish i would have gotten the sct pro esc. My 150 amp has some quirks when using 2s, battery cutoff is wrong and no reverse. Works fine with everything else though.
Old 06-06-2012, 08:57 PM
  #1342
medina619's Avatar
anyone know what size the front and rear bearings are?
medina619 is offline
Old 06-06-2012, 09:26 PM
  #1343
Trader Rating: 35 (100%+)
front: 5x16x5
rear: 5x11x4
kazuaki is offline
Old 06-06-2012, 09:39 PM
  #1344
medina619's Avatar
Originally Posted by kazuaki View Post
front: 5x16x5
rear: 5x11x4
thank you sir!
Old 06-06-2012, 10:00 PM
  #1345
medina619's Avatar
im on avid and am wondering if a rear rubber sealed bearing is ok to use?
rear
http://www.avidrc.com/product/1/bear...-bearings.html
front
Old 06-07-2012, 04:26 AM
  #1346
A metal shielded bearing would be better.
iamahuman is offline
Old 07-11-2012, 10:08 AM
  #1347
Default Wire broken
Yesterday I noticed that one of the wires from my Tenshock motor was broken in the can end. Since there no "soldering tabs" in this motor, this is going to be quite tricky to fix. Anyone else had similar issues and any good suggestions how to fix this?
micsa is offline
Old 07-11-2012, 11:49 AM
  #1348
lemonader83's Avatar
Trader Rating: 16 (100%+)
Originally Posted by symmetricon View Post
Castles great, but it doesnt have a 5mm shaft and cant compare the the specs of these motors.
200amp max
2000watts
and the 1/8 motor, a 6 pole motor, freaking thing makes 5hp.
Would I be crazy to try and put this thing in my Rustler? Looking for hp and high speeds....
Any thoughts, some are better than none!
lemonader83 is offline
Old 07-11-2012, 12:45 PM
  #1349
Ramos617's Avatar
This motor would be awesome in a rustler
I Would go with the 4000kv or the 4600kv
Ramos617 is offline
Old 07-22-2012, 03:21 PM
  #1350
I have the 4000kv in my rustler but haven't run it yet, but in the living room for a minute. I'm gonna try 14/54 at first then may try 18/54 on 3s and see what it does.
Baltim0re28 is offline
