tenshock sc401  short course Brushless MOTOR >
Old 01-14-2012, 08:29 PM
  #1171
Trader Rating: 18 (100%+)
Originally Posted by AlGio View Post
I just installed a sc411 4000 sensored with the MMP in a losi SCTE. It is set to smart sense and was wonering how much advance can a 4 pole motor take. I had the 411 3800 non sensored at 5 Deg with plenty of power but would get some cogging from time to time so switched to the sensored one.
I have it set to 10 Deg. which is the normal setting. Should I drop it down to 5 or can it take more? Thanks
4 pole motors don't like timing...Personally I run 0, but 10 shouldn't do much either way.
teknic is offline
Old 01-14-2012, 08:31 PM
  #1172
Originally Posted by Ramos617 View Post
For those running with a MMP can you please post up your setup
I'm currently running a slash 4x4 with a center diff with 14/54 gearing, tenshock 4000kv, MMP, castle bec, turnigy servo, traxxas 2.4ghz combo, gens ace 5000mah 40c 2s Lipo
No matter what esc setting I try I get cogging at startup
Today I went to a track and at times the motor would just stop and would barely respond to any throttle then go back to normal, it coggs on startup only and half the time when trying to reverse
this cogging is driving me crazy and I just want it gone
Im running deans and have solid solder joints all around any advice ?
Which motor are you running the SC401 or SC411?
teknic is offline
Old 01-14-2012, 08:43 PM
  #1173
This is the problem I was having and switched from sensorless to the sensored tenshock and the problem appears to be gone thus far. I will know for sure at the next race. I am also running the cc bec and a Savox 1258 servo.
AlGio is offline
Old 01-14-2012, 08:50 PM
  #1174
I'm a basher and never race but here are the ESC settings I use
Start Power High
Torque Limit Disabled
Punch Disabled
0 Timing
After calibrating try adding some throttle trim until just before the car starts to move on a flat surface
Can also try rolling back the ESC software, sometimes makes a difference
Cheers
crusey_aus is offline
Old 01-14-2012, 09:29 PM
  #1175
Ramos617's Avatar
Its the sc401 sensorless version and the esc is the hpi q-base which is the hpi version from the savage flux 2350 so the software is locked to 1.24
I tried different esc setting med and high start power no timing and also the trim and it still coggs
Ramos617 is offline
Old 01-14-2012, 09:34 PM
  #1176
That could be a problem
I would send the ESC into Castle and get them to unlock it
Cheers
Old 01-15-2012, 03:53 AM
  #1177
Ramos617's Avatar
I'll give them a call and see what they say
Ramos617 is offline
Old 01-15-2012, 05:16 AM
  #1178
wsl439's Avatar
Default ?
can i use 4600kv on 1/8 buggy?
wsl439 is offline
Old 01-15-2012, 05:34 AM
  #1179
No way!
Get a dedicated 1/8 BL system.
iamahuman is offline
Old 01-15-2012, 05:37 AM
  #1180
wsl439's Avatar
thanks
wsl439 is offline
Old 01-15-2012, 05:38 AM
  #1181
Not likely,
Grab one of the 6 Pole X802 motors, they make some serious grunt
Cheers
Old 01-15-2012, 10:22 AM
  #1182
j_blaze14's Avatar
Trader Rating: 34 (100%+)
4600 or 5200 in sc10 4x4? i've been melting spurs with my 6 pole motor.
j_blaze14 is offline
Old 01-15-2012, 04:42 PM
  #1183
5200 kv fo sho!!!
rickybobbyxxx is offline
Old 01-16-2012, 12:48 AM
  #1184
Trader Rating: 22 (100%+)
Which ESC is recommended for the SC411?
Honu is offline
Old 01-16-2012, 12:54 AM
  #1185
MMP or RX8
My Xerun 150 doesnt run mine well at all, it gets far too hot for my liking
Those running ESC's that have dual drive type modes (switching between sensored / sensorless) seem to be having better luck
Not sure if it can be fixed in software which apparently HW are working on
Cheers
