tenshock sc401  short course Brushless MOTOR >
Old 09-23-2011, 12:50 PM
  #871
chucko's Avatar
http://message.aliexpress.com/messag...-products.html
Try this if you want to get a hold of the guy selling them.
chucko is offline
Old 09-23-2011, 12:51 PM
  #872
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Thanks bud
aloksatoor is offline
Old 09-23-2011, 05:31 PM
  #873
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
if anyone need a ts motor i got a brand new one 4000kv sitting here that i havent had time to use. ill just buy another one later when they come available
Mr.juarez is offline
Old 09-28-2011, 03:38 PM
  #874
aloksatoor's Avatar
Any starting settings for a 6.7 pound truck with the sc401 4000kv with hobbywing sc8? I want around 10 minute run time. Running an FDR of 11 or close to it. Have set all punch and timing to lowest possible on the SC8.
Old 09-28-2011, 07:39 PM
  #875
That is what I'd go with. Try running it in race conditions and check the temps every two minutes...
iamahuman is offline
Old 09-28-2011, 08:23 PM
  #876
RC*PHREAK's Avatar
Trader Rating: 140 (100%+)
Sounds like you have the FDR and esc settings in order. What settings are you asking about? As far as 10 minutes, in a heavy truck like that, I'm pretty sure you'll need at least a 6000mah battery.
RC*PHREAK is offline
Old 09-28-2011, 09:13 PM
  #877
aloksatoor's Avatar
Ok cool. I have around 40C batteries with the sc8. Will try to keep temps around the 160 mark or so.
The esc punch, amts timing,drag brake etc settings I was referring too.
BTW tested the brakes on the tenshock/sc8 combo and these are the best sensorless brakes I have ever seen thus far.... super linear and smooth even with ABS off absolutely no slip/lock....
Old 09-28-2011, 11:13 PM
  #878
RC*PHREAK's Avatar
ok. i ran my punch at 5 (have run as high as 7 with no problem), timing at level 3 (7.5) and zero drag brake (level 1).
yes the brakes are smooth as well as the throttle. it really is a terrific, economical system.
Old 09-29-2011, 08:00 AM
  #879
lowroad's Avatar
Trader Rating: 79 (100%+)
same, except I have my punch up to 9 It's so fast I really have my end point on my tx set down to 75% just so I make sure I don't land in the next lane of the track when clearing large jumps, and it's STILL a handful.
lowroad is offline
Old 09-29-2011, 08:18 AM
  #880
Then why don't you set the end point to 100% and go down to punch level 5 or 6 and see how you like it?
Old 09-29-2011, 08:29 AM
  #881
lowroad's Avatar
why? It's fine where it is, and I like it.
lowroad is offline
Old 09-29-2011, 09:03 AM
  #882
Alright.
Old 09-29-2011, 09:10 AM
  #883
RC*PHREAK's Avatar
They do different things. Punch control effects power down low by limiting power from start up to low RPM. It's used so you're not wasting power spinning your wheels. If you run on high traction it's not needed unless you're looking to lower temps maybe. Turning down the EPA just limits top speed.
Old 09-29-2011, 09:17 AM
  #884
lowroad's Avatar
yeah, I'm on a very nigh bite sugared track without a lot of run up before quads, etc.. I'm good where I'm at.
lowroad is offline
Old 09-29-2011, 09:23 AM
  #885
Curious why you dont just fit a smaller pinion and leave the EPA at 100% ?
ESC works more efficiently when WOT = 100% Duty Cycle
Cheers
crusey_aus is offline
