tenshock sc401  short course Brushless MOTOR >
Old 09-02-2011, 06:33 AM
  #781
Trader Rating: 19 (100%+)
Any thoughts on if a mmp/4600 combo would work better on 3s? Ive had no luck w it on 2s...
nitro0619 is offline
Old 09-02-2011, 06:40 AM
  #782
Artikbot's Avatar
Well, it is a rather fast motor, is it geared properly?
Artikbot is offline
Old 09-02-2011, 06:55 AM
  #783
Its not a gearing issue its a major cogging issue.....it basically is undriveable in my truck on 2s. It just cogs too bad. Havent tried a castle bec on it yet but was thinkin a 3s lipo might be the answer
Old 09-02-2011, 08:21 AM
  #784
Cptn Cartwheel's Avatar
the MMP is the problem. They just dont work with these motors. Buy an RX8 if you can find one.
Cptn Cartwheel is offline
Old 09-02-2011, 08:38 AM
  #785
Ridley's Avatar
If you are running a 2s lipo, just run jumpers to your RX and give it direct power and bypass the MMP internal BEC altogether. That may fix your issues. I have guys bring me their MMP powered 4x4's all the time at the track to try to get them to run right, and thats first thing I have them try. It usually works pretty well, but not always.
Also, make sure your switch is working. I see those go bad and send the MMP into fits as well.
Ridley is offline
Old 09-02-2011, 09:07 AM
  #786
Thx josh i will give that a try. I just hate to not b able to run this motor as ive seen its potential. So 7.4v wont damage a spek rx?
Old 09-02-2011, 10:39 AM
  #787
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
all my switches went out within a few packs of being new. my friend mmp was having switch issues before he even ran 1 pack, so what we do now before installing is just clip those useless things off
Mr.juarez is offline
Old 09-02-2011, 02:23 PM
  #788
RC*PHREAK's Avatar
Trader Rating: 140 (100%+)
Ridley, what are your esc settings? I just picked up a used RX8 and know nothing about it.
RC*PHREAK is offline
Old 09-02-2011, 02:51 PM
  #789
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Hey Tim,
Here are my settings out of Hotwire. I can help you set it up tomorrow at NorCal if you'd like.
Setup screen:
Custom cutoff at 7.2V
BL-FW
Timing profile C1 or C2
Brake screen:
0% drag brake
75% brake strength
0% push control
10% brake minimum
Throttle screen:
Throttle profile 3
Neutral width at minimum
15% minimum throttle
85% current limit
Timing screen:
50% timing advance (this equates to about 15 degrees)
Good luck,
Chris
ChrisAttebery is offline
Old 09-02-2011, 02:55 PM
  #790
RC*PHREAK's Avatar
Originally Posted by ChrisAttebery View Post
Hey Tim,
Setup screen:
BL-FW
Brake screen:
0% drag brake
75% brake strength
0% push control
10% brake minimum
Throttle screen:
Throttle profile 3
85% current limit
Timing screen:
Good luck,
Chris
yeah, i'd love the help. i don't intend to run it tomorrow. i just want to confirm it works so i can give the guy positive feedback. i just hooked it up and it cogs like a mofo. i have no idea what the settings on it are (it's used). all those tiny lights are tough to decipher.
thanks chris!
Old 09-02-2011, 03:10 PM
  #791
It's probably the minimum throttle. I turned mine up a bit because compared to the Novak 4.5 the TenShock needed more throttle to start rolling.
thanks chris!
Old 09-02-2011, 03:41 PM
  #792
Originally Posted by Vismund View Post
Any suggestions for gearing a 4600 in a SCRT10?
Well, no success so far, let me repeat my question, geraing for scrt10 with a 4600? any idea? Someone?
Vismund is offline
Old 09-02-2011, 03:53 PM
  #793
Well, you want a FDR of about 11.6:1. What is the gear ratio of the internal gearboxes?
Old 09-02-2011, 10:01 PM
  #794
well the scrt10 has a 46 spur, and the losi has a 40. most are saying 13-14 t pinion for the losi so Id say 16-17 as a guess for your truck. run it for 2 minutes, check temps, and go from there.
Old 09-03-2011, 12:23 AM
  #795
anyone know where i can find another 5200kv to pick up as a back up? or maybe someone has one laying around they want to sell me?
RC demon is offline
