tenshock sc401 short course Brushless MOTOR
#766
i was leaning towards the sensor and sensorless esc as there is room in the future for sensor motor althought im not sure if i will ever go there. i prefer the trackside tunning card as you can mess with it every where, but it is what it is.
there is a dealer on ebay that was selling a lot of those sc8 for 70 bucks shipped i believe, but they are sold out unless this is a new replacement?
http://www.hobbypartz.com/07e-ezrun-150a-pro-esc.html
I will prolly be reassuring that it's a higher amp rating but unless you run a super hardcore heavy/large vehicle, a 120a is all you need.
#767
#768
#769
#770
I think the MMP is actually rated somewhere around 120 amps even though castle refuses to give exact specs. The main issues of the MMP isn't supplying the motor with power though, it's with supplying the esc and servo with power, and with it's actual firmware. The Tenshock isn't the only motor the MMP has issues with though, You can pretty much add any motor bigger than a 540 2 pole to that list when trying to run on 2s lipo
i agree though. i could never get my mmp with a BEC to NOT cog with a novak 4.5 550. it wasn't horrible cogging, but it cogged at WOT.
#771
http://www.castlespecialprojects.com...ntrollers.html
I have a MMP I've been using in my 2wd sct to sell yet, and then I'll be completely free of castle products
#772
sure it is. A turn is a turn, whether it's on a type of pavement or a type of dirt or clay. Every space between them is a drag race, that's why we're buying Castle 1410's and Tenshocks and Tekin 4 poles. Proline stuff works good out here at most of our tracks. In the morning you'll run an M3 compound, when it heats up mid day go to an M2, and when it cools off in the afternoon and the track is grooved up you run an M4. Just like in California most run the J Concepts stuff (I've been told) and run greens but when its really hot they put on the orange compound. We all want the most power and traction. Racing is racing and winning is winning. Power is nothing without control, and control comes from tires first, then setup. With these amazing motors you really notice a huge difference once you get it right. Thats why tire manufacturers put up charts with temperature ratings that tell what type of tire to run based on temps. Some tracks hold more heat than others. When it's 85 here the track temp can be as much as 110.
#773
is it ok to run 3's on the ten shock 401 4000KV motor with a RX8 in a TEN 4X4 ?Thanks
#774
Any suggestions for gearing a 4600 in a SCRT10?
#775
#777
However, if you are talking about the RX8, then I agree, it works great with everything I've tried.
#778
What's has a 780 burst amp rating? If you are referring to the castle MMP, I highly disagree with it working perfectly for any motor. It hardly works for anything on 2s as it's internal BEC is beyond pathetic
Talking about the hobbywing xerun 120a.
#779
