tenshock sc401  short course Brushless MOTOR >
Old 05-24-2011, 07:01 AM
  #271
mc4798's Avatar
Originally Posted by Slashdrivr View Post
Trans ratio is 2.57
They come with either a 93T 48P spur or a 62T 32P spur...
I would start with a 12-13t 32p pinion.
Does anyone make a 48p 5mm bore pinion ?
mc4798 is offline
Old 05-24-2011, 07:18 AM
  #272
I got my tenshock sc401 last friday. I run a hyper 10sc and use my trusty old school mamba max( I only run 2-3s and dont plan on running sensored so why change). As of now I'm running a 13t gear and its fast. I can run through a 5000 pack and both the esc and motor are barely warm to the touch (though it is 60 out). I tried 3s and its crazy. Nice motor, great deal. The Ofna heat sink fits perfect but no need.
929rog is offline
Old 05-24-2011, 08:19 AM
  #273
http://www.rcrockcrawling.com/index.php?cPath=52
or here:
http://kershawdesigns.com/
Sal Bandini is offline
Old 05-24-2011, 08:36 AM
  #274
mc4798's Avatar
Thanks for the links
mc4798 is offline
Old 05-24-2011, 10:45 PM
  #275
subaru_tech's Avatar
Trader Rating: 106 (100%+)
hopefully some here can give a answer.
i only have ran sensored motors.accept for a sc10rtr that was just horrible in throttle control.
are the tenshock or sensorless motors able to be smoothed out close to sensored with the speedo.
subaru_tech is offline
Old 05-24-2011, 10:47 PM
  #276
They exhibit a small amount of cogging but no worse than any other sensorless motor
Cheers
crusey_aus is offline
Old 05-25-2011, 03:55 AM
  #277
mc4798's Avatar
Cannot compare the SC10 RTR sensorless motor to the Tenshock motor. The Tenshock is of much better quality .
Like crusey said, All Sensorless motors exhibit low speed cogging. If you like to drive at 1-2 mph your gonna have some cogging no matter what motor or esc you use.
The tenshock is very smooth through out the throttle range.
mc4798 is offline
Old 05-27-2011, 07:22 AM
  #278
mc4798's Avatar
Anyone with special memorial weekend plans ?
Who is racing and where ?
mc4798 is offline
Old 05-27-2011, 12:53 PM
  #279
RC*PHREAK's Avatar
Trader Rating: 140 (100%+)
i'll be racing tonight at delta rc in antioch, ca.
RC*PHREAK is offline
Old 05-28-2011, 02:01 AM
  #280
mc4798's Avatar
Good luck !!
I messed around with diffrent motors/esc and today.
4000kv using the SC10 speed controller, In a nexx 10sc without issue. ESC was nice and cool so i would say that is pretty safe to use.
Tried the 4600kv using a xerun 120a v2.1, Turned timing down and punch at 7 everything worked great. Cogging was minimal at low speeds and acceleration felt very good.
mc4798 is offline
Old 05-29-2011, 01:20 AM
  #281
w00kie's Avatar
thanks for that, just ordered a 11t and a 13t pinion from amain.
ill start with the 13 and see how my temps go.
ive got the 5200kv on the way with a sc8 speedy from the same company.
Just a question, could someone explain to me how the kv works. the lower the kv the more top speed, acceleration, etc etc etc?
thanks for all the help. i cooked my 5.5 motor in im my sc10 4x4, got up to about 130 degrees celcius, and desoldered itself inside.
im currently running a 13.5t geared to the max, seems good buy i cant wait for the tenshock.
w00kie is offline
Old 05-29-2011, 01:24 AM
  #282
KV is a measure to represent rpms per volt
4600kv = 34,000 rpms
5200kv = 38,000 rpms
If everything else stays the same a higher kv motor will make the motor spin faster (higher top speed)
Not worth comparing motors from different manufacturers based on KV as they all construct motors differently
Decide what batteries you plan to run
Decide what speed you want
Select a motor / esc combo that will allow it without excess heat
Cheers
Old 05-30-2011, 03:44 PM
  #283
just ordered a 5200kv and the sc8 from aliexpress, since the shipping faster for the same price i could get it from somewhere else. i will also be getting a 11t and 12t pinion from amainhobbies. cant wait to get it
RC demon is offline
Old 05-30-2011, 05:24 PM
  #284
mc4798's Avatar
Sounds fun!!
What you putting it in ?
mc4798 is offline
Old 05-30-2011, 08:33 PM
  #285
my slash 4x4, which i should get my ssc lcg chassis for within a month.
RC demon is offline
