Looking for help with Castle MMM ESC > Looking for help with Castle MMM ESC
Old 02-14-2011, 10:50 AM
pswag115's Avatar
Default Looking for help with Castle MMM ESC
I'm trying to troubleshoot a friends Savage Flux. On six cells it has started acting oddly. When at at dead stop, pull the throttle to a set amount and hold, truck will start moving slowly for approx 2 sec then instantly go to whatever throttle position you have held. I've tried updating firmware, changing start power, reset to defaults, even swapping my mmm out of my revo. My mmm acted the same. With only one batt hooked up (3s) it worked fine. I'm considering it may be the batts, but it happens at any throttle position and does not happen on only one batt. I'm running out of ideas. My friend states it just started happening one day. Batts are the same since day one. Any help would be great.
pswag115 is offline
Old 02-14-2011, 10:57 AM
bigben1165's Avatar
is the motor turning freely?
bigben1165 is offline
Old 02-14-2011, 11:59 AM
T. Herwig's Avatar
Trader Rating: 25 (100%+)
What kind of transmitter are you using? Have you attempted to troubleshoot this aspect?
T. Herwig is offline
Old 02-14-2011, 12:04 PM
bigben1165's Avatar
i had a MMM fry because the motor had siezed up. i guess trouble shoot one thing at a time and narrow it down to what you think may be the cause. if it is the speed control CC has great customer service.
Old 02-14-2011, 01:07 PM
Trader Rating: 21 (100%+)
Any chance you could see what the esc's LEDs are doing when its moving slowly? If something going on with the MMM, LEDs may be telling you what's causing probs.
Duster_360 is offline
Old 02-14-2011, 02:00 PM
pswag115's Avatar
I should have posted about the radio. Its the stock pos HPI am radio. No setting that could cause this behavior. Like I posted I swapped in my MMM and it did the same. They are on the current firmware with default settings. I didn't check the motor. If you are moving already it acts normal. Its just start up.
pswag115 is offline
Old 02-14-2011, 02:12 PM
pswag115's Avatar
I'm hoping one of the castle crew catches this one and can add some input on settings that can cause this.
pswag115 is offline
Old 02-14-2011, 02:49 PM
bigben1165's Avatar
id call CC, their # is on their web site and their tech dept is very easy to work with.
Old 02-14-2011, 02:53 PM
LunchboX3904's Avatar
well it's obviously the motor if your speedo does the same thing. is it jerky at all when it's doing the slow start thing? could be the esc isnt getting enough feedback from the motor. maybe solder joints on the motor?
LunchboX3904 is offline
Old 02-14-2011, 03:15 PM
pswag115's Avatar
It does not do it on 3s only 6s. I would think that eliminates the motor.
pswag115 is offline
Old 02-14-2011, 03:16 PM
pswag115's Avatar
Does castle do the tech if its HPI branded?
pswag115 is offline
Old 02-14-2011, 04:12 PM
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Did you try a stutter stopper or an external BEC. I know with todays servos alot of esc's are having problems with stuff like that and alot of times its due to the receiver loosinga little voltage and causing alot of the problems.
wyd is offline
Old 02-14-2011, 04:26 PM
Castle has said they will, but prefer that you go thru HPI - ques was asked on their thread on RCMonster.
Old 02-14-2011, 04:44 PM
pswag115's Avatar
Brian, no i didn't try a cap. Its all stock. The good on 3s and bad on 6s has me baffled. Its not to hard to do that though.......
pswag115 is offline
