Old 02-14-2011, 05:15 PM   #16
The "floating in air" magnetic bearings that the Top Flite balancer has have got to be the lowest friction bearings out there. The lower the friction, the more accurate the balance. Wind resistance on the rotating prop or wheel is about all the drag there would be. Suspended in a magnetic field! High school physics in action.
The price is low because no precision machined bearings are required. Approaching the problem using a different technology achieves greater accuracy and lower cost. Very smart. I'm sold.
Rufus2010 is offline   Reply With Quote
Old 02-14-2011, 05:16 PM   #17
argyle43's Avatar
Trader Rating: 60 (100%+)
Default Losi & Dubro
I have the Losi and Dubro. Bought the Dubro used on this site for $15, bought the Losi and 1/10 adapter new, then had to buy decent bearings for it, then had to smooth out the rough surfaces where the shafts spin....used cheap dubro still spins better!!!
argyle43 is offline   Reply With Quote
Old 02-14-2011, 05:22 PM   #18
mellow's Avatar
Trader Rating: 21 (100%+)
Has me sold too!
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 02-15-2011, 12:20 AM   #19
JsK
JsK's Avatar
I have the magnetic TopFlite one also. It works very well, I use it for
smaller items, but...... it does have a weight limit. So the although the
TopFlite unit is more precise its not as versitile as the DuBro unit that
I recomended. As long as you never want to do a MT or Truggy tire
the TopFlite will work fine.
JsK is offline   Reply With Quote
Old 02-15-2011, 01:16 AM   #20
mellow's Avatar
I might run 1/8 buggy in the future, but for the time being only going to be balancing 1/10 buggy tires.
What do you want to see in 1:10 buggy and truck from Pro-Line? Up&comer Electric Off-Road 491 10-19-2014 07:38 PM
tire balancer gvh82 Electric Off-Road 17 12-15-2008 06:43 AM
